Hello Guest it is November 23, 2026, 05:13:57 AM
Author Topic: Enroute to Mach 3 cutting problem-seeking advice  (Read 11734 times)
« on: August 19, 2011, 08:21:16 AM »
Hi guys. 1st post here and well..yeah is about a problem..
I recently upgraded my computer (Win7) and cnc program to Mach3 v3. ,running on a Warthog. Set up M3 to the max of my knowledge,like 2 weeks ago. its cuts but..always when starting a job cuts a double circle on the bottom left side corner. Cant figure out what it is. thinking on setting up M3 on XP based PC,see if that helps, or reinstalling the drivers and registry thingy. Oh i also used a wizard for a circle thing that really looks  alike to the ones embedded on the g-codes.
here is the gcode I'm using created with enroute 3:
 N10 G90
 N20 G54
 N30 G00 X3.1538 Y2.44 Z1.0
 N40 G01 Z-0.125 F10.0
 N50 G01 X3.154 Y2.4819 F100.0
 N60 G01 X3.1538 Y2.5205
 N70 G01 Y2.5257
 N80 G01 Y4.0598
 N90 G01 X3.1458 Y4.0678
 N100 G01 X3.1538 Y4.0598
 N110 G01 X3.1618 Y4.0678
 N120 G01 X3.1538 Y4.0598
 N130 G01 Y2.5257
 N140 G01 Y2.5205
 N150 G01 X3.154 Y2.4819
 N160 G01 X3.1538 Y2.44
 N170 G02 X3.1506 Y2.3619 I-1.2128 J0.0106
 N180 G02 X3.1442 Y2.2981 I-1.2094 J0.0886
 N190 G02 X3.1313 Y2.2234 I-0.7975 J0.0989
 N200 G01 X3.1265 Y2.2067
 N210 G02 X3.1076 Y2.1617 I-0.2599 J0.0832
 N220 G01 X3.1053 Y2.1575
 N230 G02 X3.0873 Y2.1301 I-0.206 J0.1159
 N240 G02 X3.0154 Y2.0619 I-0.2428 J0.184
 N250 G02 X2.9867 Y2.0447 I-0.1711 J0.2523
 N260 G01 X2.9805 Y2.0415
 N270 G02 X2.9356 Y2.0226 I-0.1705 J0.3414
 N280 G01 X2.9317 Y2.0212
 N290 G02 X2.8311 Y2.0 I-0.1436 J0.4316
 N300 G03 X2.9317 Y2.0212 I-0.0431 J0.4528
 N310 G01 X2.9356 Y2.0226
 N320 G03 X2.9805 Y2.0415 I-0.1256 J0.3604
 N330 G01 X2.9867 Y2.0447
 N340 G03 X3.0154 Y2.0619 I-0.1423 J0.2695
 N350 G03 X3.0868 Y2.1296 I-0.171 J0.2521
 N360 G03 X3.1053 Y2.1575 I-0.1876 J0.1438
 N370 G01 X3.1076 Y2.1617
 N380 G03 X3.1265 Y2.2067 I-0.241 J0.1282
 N390 G01 X3.1313 Y2.2234
 N400 G03 X3.1442 Y2.2981 I-0.7847 J0.1736
 N410 G03 X3.1506 Y2.3619 I-1.203 J0.1524
 N420 G03 X3.1538 Y2.44 I-1.2096 J0.0886
 N430 G00 Z1.0
 N440 G00 X2.3965 Y2.4334
 N450 G01 Z-0.125 F10.0
 N460 G01 X2.4089 Y2.4215 F100.0
 N470 G01 X2.4196 Y2.4321
 N480 G01 X2.4089 Y2.4215
 N490 G01 X2.4111 Y2.3491
 N500 G03 X2.4164 Y2.2831 I0.7578 J0.0269
 N510 G01 X2.4192 Y2.2627
 N520 G01 X2.4202 Y2.256
 N530 G03 X2.4253 Y2.229 I0.2933 J0.0418
 N540 G01 X2.4273 Y2.2213
 N550 G03 X2.4397 Y2.1852 I0.257 J0.0686
 N560 G03 X2.5077 Y2.0979 I0.2958 J0.1603
 N570 G01 X2.5166 Y2.09
 N580 G03 X2.5585 Y2.0602 I0.2124 J0.2537
 N590 G01 X2.5631 Y2.0574
 N600 G03 X2.6206 Y2.0283 I0.2125 J0.3486
 N610 G02 X2.5631 Y2.0574 I0.155 J0.3777
 N620 G01 X2.5585 Y2.0602
 N630 G02 X2.5166 Y2.09 I0.1706 J0.2835
 N640 G01 X2.5077 Y2.0979
 N650 G02 X2.4397 Y2.1852 I0.2279 J0.2475
 N660 G02 X2.4273 Y2.2213 I0.2445 J0.1047
 N670 G01 X2.4253 Y2.229
 N680 G02 X2.4202 Y2.256 I0.2881 J0.0688
 N690 G01 X2.4192 Y2.2627
 N700 G01 X2.4164 Y2.2831
 N710 G02 X2.4111 Y2.3491 I0.7525 J0.0929
 N720 G01 X2.4089 Y2.4215
 N730 G01 X2.3965 Y2.4334
 N740 G01 Y2.5205
 N750 G01 X2.508
 N760 G01 Y2.3485
 N770 G03 X2.5691 Y2.1469 I0.3119 J-0.0156
 N780 G03 X2.7704 Y2.0587 I0.1902 J0.1603
 N790 G03 X2.9067 Y2.0861 I0.0054 J0.325
 N800 G03 X3.0183 Y2.1996 I-0.0918 J0.2019
 N810 G03 X3.0489 Y2.3113 I-0.4001 J0.1697
 N820 G03 X3.0574 Y2.4396 I-0.8573 J0.1209
 N830 G01 Y4.1562
 N840 G01 X3.2502
 N850 G01 Y2.5228
 N860 G02 X3.2285 Y2.2054 I-1.7364 J-0.0409
 N870 G02 X3.1534 Y2.0646 I-0.2758 J0.0569
 N880 G02 X3.0056 Y1.9707 I-0.2738 J0.2673
 N890 G02 X2.5313 Y1.9963 I-0.2049 J0.61
 N900 G02 X2.3584 Y2.1357 I0.1586 J0.3737
 N910 G02 X2.3247 Y2.2499 I0.2747 J0.1433
 N920 G02 X2.3088 Y2.5205 I1.7711 J0.2396
 N930 G01 X2.3965
 N940 G00 Z1.0
 N950 G00 X2.9016 Y5.2418
 N960 G01 Z-0.125 F10.0
 N970 G03 X1.3107 Y1.4001 I0.0 J-2.2502 F100.0
 N980 G03 X5.1524 Y2.991 I1.5913 J1.5912
 N990 G03 X2.9016 Y5.2418 I-2.2504 J0.0004
 N1000 G01 X2.9015 Y5.1178
 N1010 G03 X0.7749 Y2.991 I0.0018 J-2.1284
 N1020 G03 X2.9016 Y0.8643 I2.1284 J0.0016
 N1030 G03 X5.0283 Y2.991 I-0.0017 J2.1284
 N1040 G03 X2.9016 Y5.1178 I-2.1285 J-0.0017
 N1050 G00 Z1.0
 N1060 G00 X2.3965 Y2.4334
 N1070 G01 Z-0.125 F10.0
 N1080 G01 X2.4089 Y2.4215 F100.0
 N1090 G01 X2.4196 Y2.4321
 N1100 G01 X2.4089 Y2.4215
 N1110 G01 X2.4111 Y2.3491
 N1120 G03 X2.4164 Y2.2831 I0.7578 J0.0269
 N1130 G01 X2.4192 Y2.2627
 N1140 G01 X2.4202 Y2.256
 N1150 G03 X2.4253 Y2.229 I0.2933 J0.0418
 N1160 G01 X2.4273 Y2.2213
 N1170 G03 X2.4397 Y2.1852 I0.257 J0.0686
 N1180 G03 X2.5077 Y2.0979 I0.2958 J0.1603
 N1190 G01 X2.5166 Y2.09
 N1200 G03 X2.5585 Y2.0602 I0.2124 J0.2537
 N1210 G01 X2.5631 Y2.0574
 N1220 G03 X2.6206 Y2.0283 I0.2125 J0.3486
 N1230 G02 X2.5631 Y2.0574 I0.155 J0.3777
 N1240 G01 X2.5585 Y2.0602
 N1250 G02 X2.5166 Y2.09 I0.1706 J0.2835
 N1260 G01 X2.5077 Y2.0979
 N1270 G02 X2.4397 Y2.1852 I0.2279 J0.2475
 N1280 G02 X2.4273 Y2.2213 I0.2445 J0.1047
 N1290 G01 X2.4253 Y2.229
 N1300 G02 X2.4202 Y2.256 I0.2881 J0.0688
 N1310 G01 X2.4192 Y2.2627
 N1320 G01 X2.4164 Y2.2831
 N1330 G02 X2.4111 Y2.3491 I0.7525 J0.0929
 N1340 G01 X2.4089 Y2.4215
 N1350 G01 X2.3965 Y2.4334
 N1360 G01 Y2.5205
 N1370 G01 X2.508
 N1380 G01 Y2.3485
 N1390 G03 X2.5691 Y2.1469 I0.3119 J-0.0156
 N1400 G03 X2.7704 Y2.0587 I0.1902 J0.1603
 N1410 G03 X2.9067 Y2.0861 I0.0054 J0.325
 N1420 G03 X3.0183 Y2.1996 I-0.0918 J0.2019
 N1430 G03 X3.0489 Y2.3113 I-0.4001 J0.1697
 N1440 G03 X3.0574 Y2.4396 I-0.8573 J0.1209
 N1450 G01 Y4.1562
 N1460 G01 X3.2502
 N1470 G01 Y2.5228
 N1480 G02 X3.2285 Y2.2054 I-1.7364 J-0.0409
 N1490 G02 X3.1534 Y2.0646 I-0.2758 J0.0569
 N1500 G02 X3.0056 Y1.9707 I-0.2738 J0.2673
 N1510 G02 X2.5313 Y1.9963 I-0.2049 J0.61
 N1520 G02 X2.3584 Y2.1357 I0.1586 J0.3737
 N1530 G02 X2.3247 Y2.2499 I0.2747 J0.1433
 N1540 G02 X2.3088 Y2.5205 I1.7711 J0.2396
 N1550 G01 X2.3965
 N1560 G00 Z1.0
 N1570 G00 X3.1538 Y2.44
 N1580 G01 Z-0.125 F10.0
 N1590 G01 X3.154 Y2.4819 F100.0
 N1600 G01 X3.1538 Y2.5205
 N1610 G01 Y2.5257
 N1620 G01 Y4.0598
 N1630 G01 X3.1458 Y4.0678
 N1640 G01 X3.1538 Y4.0598
 N1650 G01 X3.1618 Y4.0678
 N1660 G01 X3.1538 Y4.0598
 N1670 G01 Y2.5257
 N1680 G01 Y2.5205
 N1690 G01 X3.154 Y2.4819
 N1700 G01 X3.1538 Y2.44
 N1710 G02 X3.1506 Y2.3619 I-1.2128 J0.0106
 N1720 G02 X3.1442 Y2.2981 I-1.2094 J0.0886
 N1730 G02 X3.1313 Y2.2234 I-0.7975 J0.0989
 N1740 G01 X3.1265 Y2.2067
 N1750 G02 X3.1076 Y2.1617 I-0.2599 J0.0832
 N1760 G01 X3.1053 Y2.1575
 N1770 G02 X3.0873 Y2.1301 I-0.206 J0.1159
 N1780 G02 X3.0154 Y2.0619 I-0.2428 J0.184
 N1790 G02 X2.9867 Y2.0447 I-0.1711 J0.2523
 N1800 G01 X2.9805 Y2.0415
 N1810 G02 X2.9356 Y2.0226 I-0.1705 J0.3414
 N1820 G01 X2.9317 Y2.0212
 N1830 G02 X2.8311 Y2.0 I-0.1436 J0.4316
 N1840 G03 X2.9317 Y2.0212 I-0.0431 J0.4528
 N1850 G01 X2.9356 Y2.0226
 N1860 G03 X2.9805 Y2.0415 I-0.1256 J0.3604
 N1870 G01 X2.9867 Y2.0447
 N1880 G03 X3.0154 Y2.0619 I-0.1423 J0.2695
 N1890 G03 X3.0868 Y2.1296 I-0.171 J0.2521
 N1900 G03 X3.1053 Y2.1575 I-0.1876 J0.1438
 N1910 G01 X3.1076 Y2.1617
 N1920 G03 X3.1265 Y2.2067 I-0.241 J0.1282
 N1930 G01 X3.1313 Y2.2234
 N1940 G03 X3.1442 Y2.2981 I-0.7847 J0.1736
 N1950 G03 X3.1506 Y2.3619 I-1.203 J0.1524
 N1960 G03 X3.1538 Y2.44 I-1.2096 J0.0886
 N1970 G00 Z1.0
 N1980 G00 X2.9016 Y5.2418
 N1990 G01 Z-0.125 F10.0
 N2000 G03 X1.3107 Y1.4001 I0.0 J-2.2502 F100.0
 N2010 G03 X5.1524 Y2.991 I1.5913 J1.5912
 N2020 G03 X2.9016 Y5.2418 I-2.2504 J0.0004
 N2030 G01 X2.9015 Y5.1178
 N2040 G03 X0.7749 Y2.991 I0.0018 J-2.1284
 N2050 G03 X2.9016 Y0.8643 I2.1284 J0.0016
 N2060 G03 X5.0283 Y2.991 I-0.0017 J2.1284
 N2070 G03 X2.9016 Y5.1178 I-2.1285 J-0.0017
 N2080 G00 Z1.0
 N2090 G00 X2.3965 Y2.4334
 N2100 G01 Z-0.125 F10.0
 N2110 G01 X2.4089 Y2.4215 F100.0
 N2120 G01 X2.4196 Y2.4321
 N2130 G01 X2.4089 Y2.4215
 N2140 G01 X2.4111 Y2.3491
 N2150 G03 X2.4164 Y2.2831 I0.7578 J0.0269
 N2160 G01 X2.4192 Y2.2627
 N2170 G01 X2.4202 Y2.256
 N2180 G03 X2.4253 Y2.229 I0.2933 J0.0418
 N2190 G01 X2.4273 Y2.2213
 N2200 G03 X2.4397 Y2.1852 I0.257 J0.0686
 N2210 G03 X2.5077 Y2.0979 I0.2958 J0.1603
 N2220 G01 X2.5166 Y2.09
 N2230 G03 X2.5585 Y2.0602 I0.2124 J0.2537
 N2240 G01 X2.5631 Y2.0574
 N2250 G03 X2.6206 Y2.0283 I0.2125 J0.3486
 N2260 G02 X2.5631 Y2.0574 I0.155 J0.3777
 N2270 G01 X2.5585 Y2.0602
 N2280 G02 X2.5166 Y2.09 I0.1706 J0.2835
 N2290 G01 X2.5077 Y2.0979
 N2300 G02 X2.4397 Y2.1852 I0.2279 J0.2475
 N2310 G02 X2.4273 Y2.2213 I0.2445 J0.1047
 N2320 G01 X2.4253 Y2.229
 N2330 G02 X2.4202 Y2.256 I0.2881 J0.0688
 N2340 G01 X2.4192 Y2.2627
 N2350 G01 X2.4164 Y2.2831
 N2360 G02 X2.4111 Y2.3491 I0.7525 J0.0929
 N2370 G01 X2.4089 Y2.4215
 N2380 G01 X2.3965 Y2.4334
 N2390 G01 Y2.5205
 N2400 G01 X2.508
 N2410 G01 Y2.3485
 N2420 G03 X2.5691 Y2.1469 I0.3119 J-0.0156
 N2430 G03 X2.7704 Y2.0587 I0.1902 J0.1603
 N2440 G03 X2.9067 Y2.0861 I0.0054 J0.325
 N2450 G03 X3.0183 Y2.1996 I-0.0918 J0.2019
 N2460 G03 X3.0489 Y2.3113 I-0.4001 J0.1697
 N2470 G03 X3.0574 Y2.4396 I-0.8573 J0.1209
 N2480 G01 Y4.1562
 N2490 G01 X3.2502
 N2500 G01 Y2.5228
 N2510 G02 X3.2285 Y2.2054 I-1.7364 J-0.0409
 N2520 G02 X3.1534 Y2.0646 I-0.2758 J0.0569
 N2530 G02 X3.0056 Y1.9707 I-0.2738 J0.2673
 N2540 G02 X2.5313 Y1.9963 I-0.2049 J0.61
 N2550 G02 X2.3584 Y2.1357 I0.1586 J0.3737
 N2560 G02 X2.3247 Y2.2499 I0.2747 J0.1433
 N2570 G02 X2.3088 Y2.5205 I1.7711 J0.2396
 N2580 G01 X2.3965
 N2590 G00 Z1.0
 N2600 G00 X3.1538 Y2.44
 N2610 G01 Z-0.125 F10.0
 N2620 G01 X3.154 Y2.4819 F100.0
 N2630 G01 X3.1538 Y2.5205
 N2640 G01 Y2.5257
 N2650 G01 Y4.0598
 N2660 G01 X3.1458 Y4.0678
 N2670 G01 X3.1538 Y4.0598
 N2680 G01 X3.1618 Y4.0678
 N2690 G01 X3.1538 Y4.0598
 N2700 G01 Y2.5257
 N2710 G01 Y2.5205
 N2720 G01 X3.154 Y2.4819
 N2730 G01 X3.1538 Y2.44
 N2740 G02 X3.1506 Y2.3619 I-1.2128 J0.0106
 N2750 G02 X3.1442 Y2.2981 I-1.2094 J0.0886
 N2760 G02 X3.1313 Y2.2234 I-0.7975 J0.0989
 N2770 G01 X3.1265 Y2.2067
 N2780 G02 X3.1076 Y2.1617 I-0.2599 J0.0832
 N2790 G01 X3.1053 Y2.1575
 N2800 G02 X3.0873 Y2.1301 I-0.206 J0.1159
 N2810 G02 X3.0154 Y2.0619 I-0.2428 J0.184
 N2820 G02 X2.9867 Y2.0447 I-0.1711 J0.2523
 N2830 G01 X2.9805 Y2.0415
 N2840 G02 X2.9356 Y2.0226 I-0.1705 J0.3414
 N2850 G01 X2.9317 Y2.0212
 N2860 G02 X2.8311 Y2.0 I-0.1436 J0.4316
 N2870 G03 X2.9317 Y2.0212 I-0.0431 J0.4528
 N2880 G01 X2.9356 Y2.0226
 N2890 G03 X2.9805 Y2.0415 I-0.1256 J0.3604
 N2900 G01 X2.9867 Y2.0447
 N2910 G03 X3.0154 Y2.0619 I-0.1423 J0.2695
 N2920 G03 X3.0868 Y2.1296 I-0.171 J0.2521
 N2930 G03 X3.1053 Y2.1575 I-0.1876 J0.1438
 N2940 G01 X3.1076 Y2.1617
 N2950 G03 X3.1265 Y2.2067 I-0.241 J0.1282
 N2960 G01 X3.1313 Y2.2234
 N2970 G03 X3.1442 Y2.2981 I-0.7847 J0.1736
 N2980 G03 X3.1506 Y2.3619 I-1.203 J0.1524
 N2990 G03 X3.1538 Y2.44 I-1.2096 J0.0886
 N3000 G00 Z1.0
 N3010 G00 X2.9016 Y5.2418
 N3020 G01 Z-0.125 F10.0
 N3030 G03 X1.3107 Y1.4001 I0.0 J-2.2502 F100.0
 N3040 G03 X5.1524 Y2.991 I1.5913 J1.5912
 N3050 G03 X2.9016 Y5.2418 I-2.2504 J0.0004
 N3060 G01 X2.9015 Y5.1178
 N3070 G03 X0.7749 Y2.991 I0.0018 J-2.1284
 N3080 G03 X2.9016 Y0.8643 I2.1284 J0.0016
 N3090 G03 X5.0283 Y2.991 I-0.0017 J2.1284
 N3100 G03 X2.9016 Y5.1178 I-2.1285 J-0.0017
 N3110 G00 Z1.0
 N3120 G00 Z1.0
 N3130 M30
I've included a pic also of the double circle things..hope it helps. Thanks for any help or advice...
Uploaded with ImageShack.us
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Enroute to Mach 3 cutting problem-seeking advice
« Reply #1 on: August 19, 2011, 09:06:02 AM »
Hi Jamuto - welcome to the forum.
Your code uses incremental IJ arcs but you have Mach set in absolute IJ mode. Either set Mach to incremental on config/gen config screen. OR put a G91.1 at the beginning of your code.
Ian
« Reply #2 on: August 20, 2011, 09:57:03 AM »
Thank you Stirling now is cutting well!Double passing but cutting :D
by the way what is the best way to cut incremental or absolute?
Thanks again :D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #3 on: August 20, 2011, 12:21:16 PM »
No worries.
That, as they say, is a very good question. Unfortunately I'm not sure what the good answer is.  ;D
Ian
« Reply #4 on: August 20, 2011, 06:10:47 PM »
There are two ways that gcode that can be written relative to a reference. The controller must be able to interpret either
coding. So by default you need to run in one mode or the other. Guess one could can write the gcode with a combination of style
but that seems like asking for trouble. Depends on how the drawing was done and how you may want to check the code. So there are advantages and disadvantages from a coding point of view. But all this is somewhat irrelavant to your question.
I don't think the actual cutting is the true question as the machine will go where instructed to go.
I can't answer to which method may have some significant influence on the computer side of things.
So after a few lines of typing here, I also am not sure what the good answer is . ;)
