Hello Guest it is November 13, 2026, 09:59:39 AM
Author Topic: Mach3 thinks it's moving Z from THC but Torch height unchanged  (Read 24107 times)
Offline Bobo
  •  41 41
    • Haus Metalworks
« on: December 13, 2006, 08:02:16 AM »
I emailed Jim Cullins about this issue also. The last thing Jim had me do is add a grounding rod near the table and ground the plasma chassis and table with a 1 inch copper strap.
The problem is consistent. The THC300 sends up and down signals to Mach3 and Mach3 thinks it's moving the z axis, according to the DROs and It will quickly get to the maximum correction of +/- 1.000 inches, but when I physically measure the z on the table it is unchanged or at least no where near 1 inch of change.
The software and table function fine as a 3 axis mill including the z axis and I can plasma cut parts all day long without the THC as long as my material is flat.
Below is the simple GCode I'm using for testing.
N0030 G20 (Units: Inches)
N0040 G53 G90 G40
N150 M3
N200 G1 Y20 F90
N300 M5
N310 M30
Thx for any help.
« Last Edit: December 13, 2006, 08:06:05 AM by Bobo »
Re: Mach3 thinks it's moving Z from THC but Torch height unchanged
« Reply #1 on: December 15, 2006, 07:00:34 AM »
Set the rate to correct the axis at a low number to start with and see if it works..
www.newfangledsolutions.com
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #2 on: December 15, 2006, 07:26:37 AM »
Please forgive my ignorance.
You mean the acceleration rate of the z axis or the Z speed correction factor?
« Reply #3 on: December 16, 2006, 03:35:00 PM »
No there is a setting that is the speed setting for the plasma correction rate.. If you could please post or send me your XML and screen set that you are running and I will see where you have the setting
Brian
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #4 on: December 18, 2006, 10:58:37 AM »
Here ya go.
Thanks much.
« Reply #5 on: December 18, 2006, 11:22:39 AM »
You don't need to be in 45KHz mode so set that to be 25KHz and it should start working...
Tell me if that makes it any better
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #6 on: December 18, 2006, 11:42:43 AM »
Wow!!! I hope it's that simple.
I'll try it tonight.
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #7 on: December 21, 2006, 08:43:30 AM »
Seems to be working now.
Thanks a bunch.
« Reply #8 on: December 21, 2006, 03:26:05 PM »
No problem :)
Did you tell Jim what the problem was?
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #9 on: January 05, 2007, 12:12:08 PM »
Actually Jim stopped by to check out my set up. Great guy. THC is working great now.
Thx much.
« Last Edit: January 05, 2007, 12:14:12 PM by Bobo »
