Hello Guest it is November 19, 2026, 08:17:23 AM
Author Topic: Problems with Mastercam 10 and mach 3  (Read 11032 times)
jedimaster
« on: December 12, 2006, 01:50:02 PM »
Hi, I am having difficulties with Mastercam X and Mach 3. I see there are several choices for definition files and post processors to use within Mastercam X.(when you pick what machine there are 2 choices for 4 axis. Not sure which one to use.) I just can't seem to get the right combination. Once I import my .NC file to Mach 3, It changes stock size and doesn't position at the same zero as in the design. Can anybody help? The machine I am using is a Taig 4 axis mill (DSLS3000). Thank you.
mattford1
Re: Problems with Mastercam 10 and mach 3
« Reply #1 on: January 13, 2007, 10:12:32 PM »
Hi-
I'm having the same issues.  I'm in the middle of trying different post processors right now.
Matt
