Hello Guest it is November 13, 2026, 09:39:44 AM
Author Topic: Mach3 Mill  (Read 8484 times)
Mach3 Mill
« on: August 13, 2011, 12:57:45 AM »
i facing a problem during homing process :-
current setting is :
a. Auto Zero disable
b. with Galil PCI motion card , all axis homing is OK - turn to yellow when active (M1 Home, M2 Home and M3 Home)
during homing ,Z Axis will doing homing first , the Z Axis will move up untill Home Sensor Triggered and it move down , it continuously mov down
although Home sesnor already OFF untill hit the limit , Why ? any setting wrong ?
Re: Mach3 Mill
« Reply #1 on: August 13, 2011, 01:17:41 AM »
This will likely be a question you should ask in the Galil section as it would seem to be specific to it.
