Hello
Guest
it is
November 13, 2026, 07:01:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
NOT HOMING CORRECTLY
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NOT HOMING CORRECTLY (Read 13858 times)
inivator
102
on:
August 11, 2011, 10:21:02 AM »
FOUR AXIS PROBOTIX, Y SLAVED TO A. ON THE INPUT SIGNALS, AS LONG AS I MAKE A++ ACTIVE HIGH, I CAN JOG, MOVE WITH MDI, AND FOLLOW G CODE. WHEN THE SYSTEM HOMES TO X, IT WILL ACTIVATE THE E STOP, BUT WILL NOT MOVE OFF HOME LSWITCH OR "0".
Carnoustie, Scotland
Re: NOT HOMING CORRECTLY
Reply #1 on:
August 11, 2011, 10:53:16 AM »
Sounds like noise issue but if you attach your xml your config can be checked in case its a wrong setting.
BR549
6,965
Reply #2 on:
August 11, 2011, 11:08:57 AM »
That may be the old switch/ramp problem. as the X moves off the Home switch it momentarily resets and tells MACH to stop. It the process of Mach stopping the switch tension relaxes and the switch reopens. BUT now Mach thinks it is a limit switch and Estops the system.
Sometimes you will have to do the reset/ jog off TWICE to get it to move far enought off the switch to behave.
The probelm is the overall Ramping Rate to close the switch is too slow and makes the switching process unstable. Sometimes adding in some more debounce will cure it.
Just a thought(;-)TP
inivator
102
Reply #3 on:
August 11, 2011, 11:09:24 AM »
Hope this works.
inivator
102
Reply #4 on:
August 11, 2011, 11:51:16 AM »
Here is the HML file
inivator
102
Reply #5 on:
August 11, 2011, 12:45:12 PM »
What should the Debounce numbers be set at?
Reply #6 on:
August 11, 2011, 12:47:42 PM »
I notice you dont have the switch for A set as a Home switch, that may be your problem?
Debounce Interval is normally tried at 2000 first and reduce as much as possible if it helps.
inivator
102
Reply #7 on:
August 11, 2011, 01:05:33 PM »
Thanks, I'll try it..
Print
Pages:
1
Go Up
« previous
next »
