Hello Guest it is November 12, 2026, 03:42:26 AM
Author Topic: a axis dro with galil  (Read 11826 times)
« on: August 09, 2011, 11:50:45 AM »
setting up a new 4 axis system for a customer.
can get a axis to move correct amount but a axis dro  remains at 0
this is happening both with jog and gcode
help!
latest lockdown mach. plugin downloaded off mach downloads
if its not broken yet, fit more gadgets!
Re: a axis dro with galil
« Reply #1 on: August 09, 2011, 04:52:12 PM »
weird. it shows dro correctly if i have smarterm and data record open (dro shows in mach3 as moving) close smarterm and dro doesnt move... scratching my head!
galil is 1750 model
« Reply #2 on: August 10, 2011, 07:29:16 PM »
ok. it works all the time if ive set data record from dma channel instead of 2nd fifo.
 however after a restart i have to redo this in smarterm or it switches back to 2nd fifo.
is there a command to burn the data record from dma to the control.?
just totally set up another pc to see if this was the case with another brand new 1750. same result
« Reply #3 on: August 11, 2011, 06:19:45 PM »
couldnt get this one reliable... seems ive found a glitchy bug.
ripped out and replaced with 2153.
