Hello Guest it is October 21, 2026, 10:10:58 AM
Author Topic: One minor bug  (Read 9732 times)
One minor bug
« on: December 11, 2006, 05:48:30 PM »
When I press "tab" to open the MPG window (leaving the mpg window open) and I try and open the config window for the shuttle the window does not open.
Even after I exit the mpg window I still cannot open the config window.  I need to shut down Mach3 and restart.
If I go into the mpg window then close it before I open the config window - the config window opens.  But once I have opened the mpg window and tried to open the config window it does not matter if I close the mpg window or not I still cannot open the config window.
Ok, thats enough words. Minor problem.
Dan.
Re: One minor bug
« Reply #1 on: December 11, 2006, 07:25:45 PM »
My bad,
the problem was a either that I had the incorrect shuttlepro driver or my USB controller needing updating.  I did both and all is well in the world.
Thanks.
Dan.
