Hello Guest it is November 14, 2026, 05:46:00 PM
Author Topic: CNC MISSING THE ODD STEP  (Read 17131 times)
« on: August 04, 2011, 07:32:47 PM »
Hi Can anyone give me some advise on my Machine missing steps.
I have a TB6560 driver board. When machening I loose the odd step after a few minutes of working.
I disconnected the screw from the stepper and it did the same. I change to 36000mhz but still no difference.
I reduced the velocity and acceleration , it is slightly better but still looses a step every now and then.
It appears to be getting worse. My gut feel is the TB6560 is the problem(chinese driver so I guess I goy what I paid for.)
Am I on the right track?
Jim
  •  9,377 9,377
Re: CNC MISSING THE ODD STEP
« Reply #1 on: August 05, 2011, 01:37:41 AM »
Hi Jim,
Two things you could try;
Try selecting 'Sherline 1/2 Pulse Mode' in Config / Ports and Pins.
Try increasing the Debounce Interval in Config / General Config.
Your Kernel Speed should really be set to 25000Hz or 35000Hz.
The TB6560 is a good chip (assuming it is a genuine Toshiba and not a clone) so that Chinese board should be OK.
« Reply #2 on: August 05, 2011, 09:37:38 AM »
Check the polarity setting of the drive lines some drives "require" an active high or low OR they willl loose steps on the reversal of direction.
Just a thought, (;-)TP
Offline ERP
  •  35 35
« Reply #3 on: August 05, 2011, 10:00:46 AM »
You might also want to try increasing the pulse width, if you haven't already.
« Reply #4 on: August 05, 2011, 04:17:01 PM »
Thanks to all for your advice.
I will try all your items and see what happens.
Jim
