Hello Guest it is November 24, 2026, 06:10:34 PM
Author Topic: Re: Jogging & feedrate troubles (Mach 3 Mill)  (Read 15957 times)
« on: July 26, 2011, 01:07:56 PM »
Hi all
Am a bit new to the CNC game and have recently aquired a large format machine that is not running quite as i want it to; maybe someone can assist please?
Subject line refers; yesterday after many restarts the machine was running at 6000mm\m and cutting long spline toolpaths (Cutting a 3D pattern) without any sweat or much jerking, today after the start I could not get it to do the same. Overriding the feed rate to 200% from a 2400 baseline shows the increased speed in the 'F' DRO, but this is not reflected in the actual speed DRO; it maxes out at between 600-800mm\m. I suspect it has to do with the CV Mode, but am not able to use the CV button on the program run screen; have looked under the settings screen but no luck so far; am I missing something obvious? I would like to get out of what seems to be the 'exact' cutting mode; am running a roughing program for a 3D pattern and accuracy is not that critical.
Any help would be greatly appreciated!
« Reply #1 on: July 26, 2011, 01:10:57 PM »
4ideas
Can you attach your xml and the code you are running, you will need to either zip them or you will need to rename your xml before you can attach to the forum. To attach use the additional options button on the reply page.
« Reply #2 on: July 26, 2011, 01:27:57 PM »
Hi Hood
Zipped archive attached, thank you!
« Reply #3 on: July 26, 2011, 01:32:57 PM »
I have sent you a personal message.
« Reply #4 on: July 26, 2011, 11:50:35 PM »
Good morning Hood
Attached please find the updated XML file as discussed last night.
4ideas
Re: Re: Jogging & feedrate troubles (Mach 3 Mill)
« Reply #5 on: July 27, 2011, 03:26:35 AM »
Have yo tried since you put  the licence in the folder?
Will go look at the xml anyway in case I see some issues.
« Reply #6 on: July 27, 2011, 03:33:58 AM »
Your xml is set to Exact Stop as default and your code has not got a G64 in it so it will run in Exact Stop. Best to put a G64 at the beginning of the code and probably also best to change the default to G6 (Constant Velocity), yo can do that on General Config page.
« Reply #7 on: July 27, 2011, 01:58:50 PM »
Thank you much sir! Will give it a try....
4ideas
« Reply #8 on: July 27, 2011, 02:05:45 PM »
It should be G64 (Constant Velocity)
