Hello
Guest
it is
October 12, 2026, 04:53:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Question about timer pump for oiler with override button
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Question about timer pump for oiler with override button (Read 8875 times)
Jackal
173
on:
July 16, 2011, 10:23:35 PM »
I'm still chugging along. Getting control panel together.
If I use a Mach3 brain for a timer that oils the ways every say "8 minutes". Can I also have a temporary push button so that I can oil it a few times manually on start up?
JAckal
Logged
Everything is bio-degradable if you run over it enough with a lawnmower.
Carnoustie, Scotland
Re: Question about timer pump for oiler with override button
Reply #1 on:
July 17, 2011, 04:15:28 AM »
Yes, shouldnt be a problem, you could get fancy and probably have it resetting the timer as well but just having the button connected to the output in the Brain will do it.
Logged
Jackal
173
Reply #2 on:
July 17, 2011, 10:50:44 PM »
Thanks Hood,
I just didn't want the current to back feed and burn something up.
JAckal
Logged
Print
Pages:
1
Go Up
« previous
next »
