Hello Guest it is November 13, 2026, 12:10:32 PM
Author Topic: Breathing New Life Back Into a Shopbot PRT 48 X 96 CNC Router  (Read 37608 times)
Offline Helicopterjohn
  •  62 62
  • Seffner, Florida
    • Helicopterjohn.com
Re: Breathing New Life Back Into a Shopbot PRT 48 X 96 CNC Router
« Reply #10 on: August 08, 2011, 09:43:04 PM »
I can say for sure what made the motors run so much smoother and quieter, but it was a welcome outcome.  Replacing the Gekco 202's with the Gekco 203V's helped I am sure.
John
Shopbot PRT 48 X 96  Gekco 203V drives, PMDX-126 Multi-Mode Breakout Board, PMDX-107 Isolated Speed Control, (2) Ea. PMDX-133 3-axis Daisy-Chainable Motherboard for Gekco 203V's, PMDX-2PARPCi Dual Parallel Port Card, Super PID Speed Controller, 2010 Screen Set, Solid State Relays for dust/coolant.
  •  62 62
  • Seffner, Florida
« Reply #11 on: August 19, 2011, 10:12:06 PM »
I installed the second parallel port card and it works great.  I have also made a dual outlet box that has 3 solid state relays installed.  I removed the connector tab on one of the receptacles so that each of the two outlets could be controlled by a separate solid state relay.  My current Mach3 screenset will allow me to click on an icon and toggle my dust collector and vacuum pump on and off.  I still have one spare that can be used for another device.
Here is a link that shows the solid state relays that I used.  They are rated at 25 amps.  http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=360385301485&ssPageName=ADME:L:OU:US:1123
John
« Last Edit: August 19, 2011, 10:19:18 PM by Helicopterjohn »
« Reply #12 on: August 20, 2011, 06:19:27 AM »
Hi John,
Even though you look like you're finished with your relay box, this is a nice writeup that adds some nice features.
http://www.cartertools.com/tbbrb.html
  •  62 62
  • Seffner, Florida
« Reply #13 on: August 20, 2011, 07:17:17 AM »
Hi Dave,
Very nice link with great pictures and documentation.  Thanks for sharing.
John
« Reply #14 on: August 20, 2011, 07:18:57 AM »
