Hello
Guest
it is
October 14, 2026, 04:46:42 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
screen coordinates
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: screen coordinates (Read 11121 times)
studysession
176
screen coordinates
on:
July 13, 2011, 06:25:57 PM »
I have a problem with sometimes my system stops. As a quick fix - I just want to close and reopen MACH3 to have the same coordinates from when I close and re-open MACH3 back to the same position where it last stopped.
Thanks -
Keith
Logged
http://celticmachining.blogspot.com/
ger21
6,295
Re: screen coordinates
Reply #1 on:
July 13, 2011, 06:33:20 PM »
Persistent DRO's in General Config?
Logged
studysession
176
Reply #2 on:
July 13, 2011, 06:52:11 PM »
I found "Lock DRO's to setup units"
is that it?
When I close MACH3 it always ask "Fixtures Save?" - What does that do?
Thanks!!!!
Logged
studysession
176
Reply #3 on:
July 13, 2011, 07:02:18 PM »
I checked the "Lock DRO's to setup units"
Saved Setting
And clicked NO for fixture saved and MACH3 was not at the same coordinates when I opened it. It always seems random.
Logged
ger21
6,295
Reply #4 on:
July 13, 2011, 07:14:39 PM »
Bottom right corner of General Config, Persistant DRO's.
Fixture Save is asking to D=Save the Offsets. You can turn it off by unchecking "Optional Offset Save".
Logged
studysession
176
Reply #5 on:
July 13, 2011, 07:27:38 PM »
Gerry -
That worked!!!
Thank you!!! It does not ask the fixture save question and it saves the coordinates.
Keith
Logged
Print
Pages:
1
Go Up
« previous
next »
