Hello Guest it is September 25, 2026, 08:41:26 PM
Author Topic: Galil and Mach3 in CT  (Read 17553 times)
« on: July 11, 2011, 09:35:07 PM »
I have a Galil 1740 isa card running with Mach3.  I am getting an error that the motor is not on when I try to use either Mach3 or the Galil WSDK.  I am a total newbie and know the unit was working when I bought it.  It's using an Octagon Systems controller with SEM servo motors and encoders.  Anyone have any ideas?
Nelsonk11
Re: Galil and Mach3 in CT
« Reply #1 on: July 12, 2011, 09:46:04 AM »
You should be able to diagnose it in WSDK or Terminal.
The TS command Tell Switches not only shows Fwd/rev limit status but also error, motion and motor status.
Some reasons are MO or issue a SH to turn the motors on.
N.
« Reply #2 on: July 12, 2011, 07:19:40 PM »
I'll check that, but for some reason, wsdk thinks the motors are off--they're not, I turned them on in Mach3 with the reset and you can hear them humming.  By the way, the x axis slowly turns all the time even when not jogging or running g codes.
Nelsonk11
« Reply #3 on: July 12, 2011, 08:53:45 PM »
Nelsonk11
That is a sign that the Galil does not have control of the drive.
N.
« Reply #4 on: July 13, 2011, 08:14:07 PM »
I did a system reset and now there seems to be some control restored.  It still doesn't perform as required however.  I would like to find someone in the area who could look at it for me and suggest a remedy.
Nelsonk11
Offline kcrouch
  •  193 193
  • In way too deep!!!
« Reply #5 on: July 14, 2011, 12:11:57 PM »
Nelson,
I'm in North Andover,MA. What part of CT are you in? There are lots of prople nearby who can help.
PM me if youi want.
Kenny
Having way too much fun! Something must surely be wrong.
« Reply #6 on: July 14, 2011, 09:53:42 PM »
Kenny,
Thanks, but I'm on the shore in Guilford.  If you ever get down this way  or know anyone here please let me know.
Nelson
« Reply #7 on: July 17, 2011, 07:07:16 AM »
I am in North central CT.
PM me and I will see if we can get together.
Mike
