Hello Guest it is November 13, 2026, 02:54:42 PM
Author Topic: G00 not working right  (Read 10199 times)
« on: July 07, 2011, 02:41:29 PM »
Hello all, when I run a program and it comes to the first G00 it always runs it at the last feedrate instead of the rapid speed. Any idea why this would happen? I have searched around on the forums and didn't really find anything about it, and I didn't want to go thought 200 pages :P.
Any help would be great.
Aero
Re: G00 not working right
« Reply #1 on: July 07, 2011, 03:43:17 PM »
If you attach your code and xml maybe the issue can be found.
Offline mr.c
  •  40 40
« Reply #2 on: July 08, 2011, 07:20:53 PM »
I have had issues in the past that did the same thing. In my case it was how I wrote or edited a program. In my case, I was hitting the O key instead of the 0. The two keys are right next to each other and if I have the wrong glasses or am in a hurry it used to happen. I finally put a piece of tape over the O key so that i wasn't distracted into hitting the wrong key. This is probably not what is happening in your case but worth checking if you are manually writing your program. You said it did this on the first G00. What about any other G00's?
