Hello Guest it is November 13, 2026, 09:47:02 AM
Author Topic: Motherboards-microATX that works  (Read 11245 times)
Offline Bloy
  •  158 158
« on: July 03, 2011, 09:50:51 PM »
Hi all,
I'm setting up another machine computer and have tried an Asus A7v8x-MX motherboard that has unstable pulse, This is due I believe from the onboard video. I'm using an ATI AGP video card.
My questions are...  What MICRO ATX boards are you using that function well with Mach3?  Is there a section here that lists compatable boards of the MICRO ATX form?   I have heard that some boards have a jumper to eliminate onboard video interference.  Is this true?
The A7V8X-MX does not have this feature.
I don't need a new MICRO ATX board...just one that works
John Meissner
« Last Edit: July 03, 2011, 09:53:04 PM by Bloy »
Offline Bloy
  •  158 158
Re: Motherboards-microATX that works
« Reply #1 on: July 04, 2011, 07:51:41 PM »
Okay, the A7v8x-MX Works just fine.  This was the first time I had to use the optimizations offered.  All I had to do was go to "Standard PC" which just turned off the ACPI.  That did the trick.   Seems to run just fine now.   Woo-Hoo!
  •  9,377 9,377
« Reply #2 on: July 05, 2011, 12:48:42 AM »
Glad you got it sorted John.
Thinking about your post, maybe it would be a good idea to have a post compiling all the motherboard types that do work well with the latest versions of Mach.  ???
Offline Bloy
  •  158 158
« Reply #3 on: July 06, 2011, 12:09:15 AM »
Well, if this thread is occasionally refreshed, we can use it to enter our motherboard(s) model(s) we use in our CNC systems.
In any event, I've been using the ASUS A7V333 and A7V600 boards running Mach3 right off the bat, and now the A7V8X-MX(running in optimized "standard PC" mode).
OS WinXP
« Last Edit: July 06, 2011, 12:11:59 AM by Bloy »
