Hello Guest it is November 13, 2026, 10:20:20 AM
Author Topic: Scaling a single MPG for each axis?  (Read 13410 times)
Offline gm276
  •  14 14
« on: December 06, 2006, 09:24:50 AM »
I just implemented a single MPG to switch to each axis.
Each of my machines axis's have a different count to move an inch.
e.g. When I set up the mpg to move the X axis .100 per MPG turn it will
be different for the y axis.  Since my z axis has a very high count per inch
it is way different.
Can the single MPG be scaled per axis?  I would like to have the axis
travel the same amount per mpg turn no matter which axis I select.
Don B
Re: Scaling a single MPG for each axis?
« Reply #1 on: December 06, 2006, 05:58:51 PM »
Dont think you can :( Only way I can see to do it would be an MPG for each axis.
« Reply #2 on: December 07, 2006, 08:38:47 PM »
You need to have the MPG set up in Multi step mode
www.newfangledsolutions.com
www.machsupport.com
Offline gm276
  •  14 14
« Reply #3 on: December 08, 2006, 11:37:21 AM »
Brian and Hood,
Thank you both for your input. I have gotten multiple answers and they all vary.
Art( says no in velocity mode).
I did try the mult step mode and it did work somewhat.
The amounts traveled were the same per axis. The only complaint is the
way it moves is in a "chugging" fashion. The velocity mode is smooth.
So I guess for now I have to pick from the two methods.
The smoothness of the velocity mode is nice so perhaps I'll add a couple more
MPG's and go that way.
Don B
« Reply #4 on: December 09, 2006, 09:23:46 AM »
It is VERY hard to get machines to move the way that you would like because most of the machines that we run are very under powered :( if you crank an MPG on a large machine tool you can fault an axis... on the machines that we deal with that is missed steps.
www.machsupport.com
