Hello
Guest
it is
November 13, 2026, 04:45:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Howto use Roadrunner example in metric units?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Howto use Roadrunner example in metric units? (Read 9924 times)
hoagiem
6
on:
July 03, 2011, 03:19:31 AM »
Hi all,
on my recently build mill, the roadrunner example seems to be smaller than 1 by 1 mm. You can hear the movement, but not see it. Is there anything I can do to use this file as my first test?
Hoagie
Carnoustie, Scotland
Re: Howto use Roadrunner example in metric units?
Reply #1 on:
July 03, 2011, 03:30:56 AM »
Edit the code and put a G20 at the start of it, that will tell Mach its in imperial units and will be run as such. The other way is to use the scaling at the side of the axis DROs, you can then scale it by the amount you wish.
hoagiem
6
Reply #2 on:
July 03, 2011, 06:48:49 AM »
Hi Hood,
G20 fixed it and Roadrunner has been milled successfully.
Thank you very much!
Hoagie
Last Edit: July 03, 2011, 06:51:06 AM by hoagiem
Reply #3 on:
July 03, 2011, 12:40:40 PM »
No probs
Print
Pages:
1
Go Up
« previous
next »
