Hello Guest it is November 10, 2026, 01:56:35 AM
Author Topic: Have some problem on spindle motor and fire torch of plasma machine  (Read 6866 times)
   Hi Experters,
   I have some problem on spindle motor and the torch of plasma machine.
   I know the macro command of spindle is m03 " CW running" and m05 " stop running".
   I know the macro command of torch fire is same as spindle command ---> m03 is fire and m05 is stop fire.
   I have both spindle motor and the torch of plasma machine on Z- axis.
   If I write m03 on MDI page, the spindle motor will rotate and the torch fire also.
   Is it possible to separate command ?
    If I write m03 on MDI page, the spindle motor can rotate but the torch can not fire.
Or If I write mxx on MDI page, the spindle motor can not rotate but the torch can fire.
   How to write the command of macro ?
   Pls help
   Mongkol
Re: Have some problem on spindle motor and fire torch of plasma machine
« Reply #1 on: July 03, 2011, 09:34:07 AM »
If you're not using flood or mist, put the spindle on one of those outputs, then turn it on with an M7/8 and off with an M9.  Not sure if you can do that with a VFD spindle, but it works fine with a spindle, or any other device, that just needs a simple on/off.
« Last Edit: July 03, 2011, 09:36:04 AM by rrc1962 »
