Hello Guest it is November 17, 2026, 12:05:38 AM
Author Topic: Mach 3 Not Cutting The Size I Specifie  (Read 27205 times)
Re: Mach 3 Not Cutting The Size I Specifie
« Reply #10 on: June 22, 2011, 05:11:25 AM »
i use adobe illustrator and i export all my products to WMF files is that ok/Normal?
  ??? Sorry buddy but you have lost me here, I am not certain what you are referring to.  ???
oh sorry this is a new qeustion. everyone seem to talk about dxf files when they export to lazycam i was just wondering if the file type im using WMF is ok or is it putting me rong somehow.
« Reply #11 on: June 22, 2011, 05:14:08 AM »
Lazycam is dxf file inporter so you will need to convert the dwf to a dxf.  The dxf file contains all the vector info of the entities which  LC uses on inport to define the profile.
Yes there is a image module but there is no support on it's use and the LC manual only covers the mill module with some guidence on the lathe module ( which is replaced by LazyTurn). The magic wands , as i call them, which do raster to vector conversion, rarely provide satisfactory results.
its just that the dxf files never come out looking the way i designd them and the WMF files in lazy cam are bang on for me
« Reply #12 on: June 22, 2011, 05:31:22 AM »
If done in CAD or CAM they will.
WYSIWYG (WHAT YOU SEE IS WHAT YOU GET)  :D
