Hello Guest it is November 10, 2026, 01:58:08 AM
Author Topic: I want to shield limit signal to move X,Y,Z when "Limit Estop"  (Read 8479 times)
hello All:
I am now developing a machine controlled by mach3, when X,Y or Z move above limit position, Mach3 will always on emergency status, until I power off the machine, and move the X Y or Z by hand to leave the limit position, and then power on the machine.
my question is : when my user use my machine, I don't want him to move the X Y or Z, so I want to solve this question by the following steps:
1 Limit stop
2 I click a button in mach3 to do
   a) shield limit signal
   b) drive X Y or Z move to a safe postion
   c) active limit signal
3  machine is ok
so the techic is how to shield the limit signal in mach3 in VB ( I don't want user to change the config/ Ports and Pins),he need only click a button
Re: I want to shield limit signal to move X,Y,Z when "Limit Estop"
« Reply #1 on: June 17, 2011, 08:27:13 AM »
On the setting page (Alt6) , they're 2 functions:
1:  Manual limit override
2: Automatic limit override
Try Automatic limit override and you should be able to move your axis fromn the limit switches.
About the VB, can't help with that
Jeff
« Reply #2 on: June 17, 2011, 07:26:16 PM »
thank you jeff!
you give me a way , I will try to test, and also I found that I can modify a vb code to implement only with OEMCode=150 ,and judge all the axis positon ,and move a distinct all this finished
