Hello Guest it is November 28, 2026, 06:49:09 AM
Author Topic: Modify text file  (Read 12114 times)
Modify text file
« on: December 03, 2006, 10:22:09 AM »
Is possible to modify a sequential text file?
The only that I need to do is to change the last line.
Or delete the line and append a new line, but how I delete the line?. ???
German
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Modify text file
« Reply #1 on: December 03, 2006, 10:32:17 AM »
If you click the EDIT PROGRAM button, the text file should be sent to notepad for editing.
Graham.
« Reply #2 on: December 03, 2006, 06:14:51 PM »
Sorry,
My problem is to edit the TeachFile with VB script and modify the text within macro.
German
« Reply #3 on: December 20, 2006, 06:57:32 PM »
Perhaps you could do it in 3 seprete files.
Open the first and put in your info, upto the last line that you want to be varable.
Open and name a second file that you put your variable into, and this is an append file that will append the first and second to a 3rd. then the 3rd file you post to where ever. When you need to change it, just run the process again, 1st file loads, you put in your new info in your append file, then it re-sums file one and two, with the new appended message to the end.
scott
