Hello Guest it is November 01, 2026, 10:13:51 AM
Author Topic: lazy cam with version 2 mach 3 photo engraving prob  (Read 11700 times)
« on: December 02, 2006, 05:33:04 PM »
Hi guys   at present  use  lock down version of  mach 3 on  my  cnc   but have  latest version with lazy cam  on  laptop  to  learn  to drive befor i upgrade
I have been  trying to use lazy cam  to generate g code  to do photo engraving  i have generated g code  using the  V drill module
have set  to max depth  of  0.8 mm  with 60 deg  cutter
when i  generate  code  it gives  X  and  Y  locations  but  no  commands to  drive  the z axis
any ideas  what i am doing wrong ?
thanks  Bill
ps  any one  know  if  in  latest  Mach 3  if  the spindle speed control  works  with the feedback  loop
Re: lazy cam with version 2 mach 3 photo engraving prob
« Reply #1 on: December 03, 2006, 05:53:13 PM »
What Rev of Lcam did you run?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: December 04, 2006, 08:25:58 AM »
Hi Brian  2.66  it was with the download  of  mach 3  from  artsoft site
i have found that if in the options when you ask it to make gcode plunge clearance is  set  to  0  if  set it to  0.1 the it creates code with z at  0.1
if set 0 then it  gives no z at  all
it  may  be  that i am missing somthing vital  here  as i am  no  expert  and have only just started to try to de  engraving with my equipment
thanks  for  you  reply  bill
sample of  code
N5 (File  )
N10 (Default Mill Post)
N15 (File Posted in Mill Mode)
N20 (Monday, December 04, 2006)
N25 G90 G80 G40 G91.1
N30 G0  Z0.0000
N35  X65.5851  Y99.7922
N40 M3
N45  Y98.7634
N50  Y97.7346
N55  Y96.7059
N60  Y95.6771
N65  Y94.6483
N70  Y93.6195
N75  Y92.5907
N80  Y91.5619
N85  Y90.5331
N90  Y89.5044
N95  Y88.4756
N100  Y87.4468
N105  Y86.4180
N110  Y85.3892
N115  Y84.3604
N120  Y83.3316
N125  Y82.3029
N130  Y81.2741
N135  Y80.2453
N140  Y79.2165
N145  Y78.1877
N150  Y77.1589
N155  Y76.1301
N160  Y75.1014
N165  Y74.0726
N170  Y73.0438
« Reply #3 on: December 07, 2006, 09:24:13 PM »
If you are at zero and you would like to move to zero there is no need to send out a move... Set the rapid height and you should be good
www.machsupport.com
