Hello Guest it is November 22, 2026, 10:28:15 PM
Author Topic: "To go" DRO  (Read 11473 times)
Offline KTM
  •  92 92
"To go" DRO
« on: June 12, 2011, 03:03:57 AM »
Hi all,
I know that there is a button that changes the co-ordinate DRO's to the distance to go, but is there a dedicated DRO that shows the distance to go?
The reason why I ask this is that I wish to switch an output off when the distance to go is less than a certain value with a brain or macro.
Thanks, Steve
Re: "To go" DRO
« Reply #1 on: June 12, 2011, 03:08:02 AM »
This what you are looking for?
Offline KTM
  •  92 92
Re: "To go" DRO
« Reply #2 on: June 12, 2011, 03:59:24 AM »
 ;D Thanks Hood,
It seems that I have the old OEM code list, I've now downloaded this one - http://www.machsupport.com/forum/index.php/topic,9312.0.html, is this the latest?
Regards Steve
Re: "To go" DRO
« Reply #3 on: June 12, 2011, 06:51:54 AM »
Not sure which is the latest,  think they are all the same except Brett was doing some reordering. I just use the one I copied from the wiki and put into the xls so if thats the one you have these will be in it ;0
Re: "To go" DRO
« Reply #4 on: June 12, 2011, 07:36:16 AM »
There's also a list in the programers guide.
http://www.machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
