Hello Guest it is November 01, 2026, 01:05:34 PM
Author Topic: Import DXF  (Read 81577 times)
Import DXF
« on: June 07, 2011, 01:35:26 PM »
I have a DXF file that I'm importing into LazyCam. When it first shows up in the window, all the lines are there, then a lot of areas the lines disappear from in the final image. Anyone know why these lines are going away? Thanks.
Re: Import DXF
« Reply #1 on: June 08, 2011, 08:48:36 AM »
I'm not sure what "version" of DXF I'm creating, but what if I were to load it into AutoCAD, then save it as a 2010 DXF?
Re: Import DXF
« Reply #2 on: June 08, 2011, 11:26:08 AM »
Save it as a v12 for best results
Re: Import DXF
« Reply #3 on: June 08, 2011, 02:05:01 PM »
I opened my file in AutoCAD 2012 and saved it as DXF R12. Still have the same issue. Any other suggestions, anyone?
Re: Import DXF
« Reply #4 on: June 08, 2011, 02:40:10 PM »
Post the .dxf here
Re: Import DXF
« Reply #5 on: June 08, 2011, 02:50:36 PM »
You'll need to change the extension back to .ZIP - for some reason it wouldn't let me upload it with a ZIP extension.
Re: Import DXF
« Reply #6 on: June 08, 2011, 05:00:44 PM »
Not sure what it's supposed to be. And I don't use LazyCAM.
But here's a few reasons why you're having problems.
1) The .dxf only contains a single block. Try exploding it.
2) anything that's not an arc is a 3D polyline, which I'm not sure if LC supports? Rich?
3) there are almost 20,000  lines and arcs. I can't see how anything recognizable could be cut from this??
It looks like an attempt to use a Raster to Vector converter on a photo of a landscape??
Re: Import DXF
« Reply #7 on: June 08, 2011, 05:09:10 PM »
It's a line drawing of a landscape, yes. Any suggestions?
Re: Import DXF
« Reply #8 on: June 08, 2011, 05:14:21 PM »
The lines are all there in the DXF file, but they don't show up in LazyCam.
Re: Import DXF
« Reply #9 on: June 08, 2011, 05:34:09 PM »
I gave you two.
Try exploding the block. But my guess is that the problem is the 3D polylines, which make up most of the lines.
Try creating a .dxf file with a single 3D polyline and see if it works.
But I'll ask again. I posted a pic of the drawing. There's nothing recognizable, so why are you trying to cut it??
