Hello Guest it is November 13, 2026, 05:14:31 PM
Author Topic: intermittent interrupt on mpg pulse  (Read 13120 times)
« on: June 07, 2011, 12:45:12 PM »
I am using a pic for modbus communications and everything works except the mpg. I feed the tickcount and mpg1 count with the following interrupt code:
defs
   INTCON2bits.INTEDG1 = 0;  //Interrupt on falling edge (INT1)
     INTCON3bits.INT1IP = 1;   //INT1 External Interrupt Priority bit (Set to High)
     INTCON3bits.INT1IF = 0;   //Clear interrupt flag bit
     INTCON3bits.INT1IE = 1;   //Enable the INT1 external interrupt
   INTCON2bits.INTEDG2 = 0;  //Interrupt on falling edge (INT2)
     INTCON3bits.INT2IP = 1;   //INT2 External Interrupt Priority bit (Set to High)
     INTCON3bits.INT2IF = 0;   //Clear interrupt flag bit
     INTCON3bits.INT2IE = 1;   //Enable the INT2 external interrupt
     RCONbits.IPEN = 1;    //Enable priority levels on interrupts
    INTCONbits.GIEH = 1; // Enables all unmasked interrupts
   INTCONbits.GIEL = 1; // Enables all unmasked peripheral interrupts
then int code itself
void
handle_high_isr(
  void
   if (INTCON3bits.INT1IF)
      INTCON3bits.INT1IE = 0;
        mpg_count++;
      mpg_tickcount = (unsigned char) ReadTimer0();
      WriteTimer0( 0 );
       INTCON3bits.INT1IF = 0; // clear int flag
   if (INTCON3bits.INT2IF)
      INTCON3bits.INT2IE = 0;
      mpg_count--;
      WriteTimer0( 0 );
       INTCON3bits.INT2IF = 0; // clear int flag
   // Handle any pending USB tasks
   USBDeviceTasks();
If I spin the mpg quickly it always just registers the last movement + or -. If I move it slowly it appears to register movement at random. It is always in the right direction but may not register no matter how slow.
Any ideas?
