Hello
Guest
it is
November 13, 2026, 05:20:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach SDK plugin questions and answers.
Connecting to Machine over ethernet
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Connecting to Machine over ethernet (Read 9429 times)
jeffn
6
on:
June 04, 2011, 05:48:53 PM »
So I'm thinking about writing a driver to let my CAD/CAM computer connect direct to Mach running on the shop pc over ethernet. I know in Vcarve I can post straight to mach if its on the local machine. Is this already possible and I just missed it? Is there a place that I can find the info that it uses to create the local connection?
Thanks!
J
Logged
poppabear
2,235
Briceville, TN, USA
Re: Connecting to Machine over ethernet
Reply #1 on:
June 05, 2011, 09:16:42 AM »
if you shop computer is on your same network, then on your shop computer, (where ever you store your G code files), map-share that folder/location for the LAN. Then on your CAD/CAM comp, map that folder to the output side of your CAM post.
scott
Logged
ger21
6,295
Reply #2 on:
June 05, 2011, 12:57:04 PM »
If you want V-Carve to load g-code into Mach3 on another PC, I don't think that's possible.
I do what Scott said. My control computer has a shared drive, and I just write the files to it, or copy them to it. Then just open the code in Mach3 and cut.
Logged
jeffn
6
Reply #3 on:
June 05, 2011, 08:39:48 PM »
I hadn't done it in a long time and I seem to forget that it just saves the gcode then tells Mach to open it. I thought it actually transfered it without saving. Thanks for the suggestions!
J
Last Edit: June 05, 2011, 08:43:51 PM by jeffn
Logged
Print
Pages:
1
Go Up
« previous
next »
