Hello Guest it is October 25, 2026, 05:00:17 PM
Author Topic: Circle cutting direction description wrong  (Read 14399 times)
Offline Sage
  •  370 370
« on: June 02, 2011, 07:49:04 AM »
I'm using V2.86 wizards.
In the circle cutting wizard I select:
Groove
Inside
Clockwise (climb mill)
The code generated is correct in so far as the tool IS climb milling but it moves COUNTER-clockwise to do so.
CCW is the correct direction to climb mill inside a circle. Therefore only the description in the wizard is incorrect.
The choices will need to be re-thought since selecting inside or outside also affects the description of the direction.
Sage
