Hello Guest it is October 10, 2026, 01:28:17 PM
Author Topic: Manual Spindle Calibration *PLEASE*  (Read 23076 times)
« on: May 29, 2011, 12:03:15 PM »
My mill does not send a tach signal back to the control computer but the spindle speed is visible on the motor controller.
Since I dont have a tach signal I cannot auto-calibrate the spindle.
I wish there was a way to manually enter the spindle speed vs PWM %.
I am sure this feature would be widely appreciated!
Is there a way to manual edit linear.dat or something I can do to achieve manual calibration?
Thanks for a great program!
Offline pplug
  •  15 15
Re: Manual Spindle Calibration *PLEASE*
« Reply #1 on: June 21, 2011, 06:55:05 PM »
I second this request! With the mass proliferation of analog voltage vfd controls, I think this would be a helpful feature. I type 15000 into the spindle section and I get 14683. It is repeatable. If I can calibrate manually I could get better accuracy on the vfd.
Offline djc
  •  47 47
« Reply #2 on: June 22, 2011, 10:04:42 AM »
Can you not achieve the same thing by playing around with the pulley ratios in the spindle section?
« Reply #3 on: June 22, 2011, 11:56:39 PM »
No you cannot. If everything was linear the yes. But nothing is.
They really need to put in a proper calibration system.
Like you it increments the PWM up 5% and asks you to enter the RPM.
It continues that all the way up to 100%.
Then it builds a proper relationship between RPM and PWM.
Such a simple feature, I cannot believe it has not been implemented!
