Hello Guest it is September 04, 2026, 08:41:13 AM
Author Topic: Spindle Calibration by Manually Editing the .xml  (Read 21274 times)
« on: May 28, 2011, 08:39:18 PM »
My mill does not send a tach signal back to the control computer but the spindle speed is visible on the motor controller.
Since I dont have a tach signal I cannot auto-calibrate the spindle.
I wish there was a way to manually enter the spindle speed vs PWM %.
I think it could probably be done in the mymill.xml file.
Does anyone have any experience with editing the xml to achieve this?
Re: Spindle Calibration by Manually Editing the .xml
« Reply #1 on: May 28, 2011, 08:53:15 PM »
You might want to try playing with the pulley speeds.
« Reply #2 on: May 28, 2011, 09:20:08 PM »
I dont think its pulley speeds I need to change. Its the stored data when doing an auto-calibrate. I want to manually enter it into the xml. Or adjust whats already in there.
« Reply #3 on: May 28, 2011, 09:51:57 PM »
I don't think it's in the .xml
I think it's in the linearity.dat file/
« Reply #4 on: May 28, 2011, 09:54:31 PM »
Thanks. I just tried to open it but it is not an easily understood file.
Do you have any idea how i could edit it or understand it?
« Reply #5 on: May 28, 2011, 10:35:51 PM »
Nope. But if you delete it, a new one will be created.
« Reply #6 on: May 29, 2011, 02:24:18 AM »
That is interesting but not useful information.
I opened the Linearity.dat file in a hex editor and the structure is not easily visible....
Does anyone know how to accomplish a manual config?
I have thought about hooking a function generator up to an input pin and matching it to the displayed rpm.....
« Reply #7 on: May 29, 2011, 12:10:02 PM »
« Reply #8 on: May 29, 2011, 01:00:05 PM »
Art posted a proceedure to calibrate your spindle .Might want to do a search for it.
« Reply #9 on: May 29, 2011, 01:45:07 PM »
I found the document/discussion and posted it here.
http://www.machsupport.com/forum/index.php/topic,18580.new.html#new
Hope it helps, (;-) TP
