Hello Guest it is November 23, 2026, 05:15:15 AM
Author Topic: pci parallel port questions  (Read 15463 times)
« on: May 26, 2011, 05:29:56 PM »
Hello All
rookie here
trying to get Mach setup and running for a cnc router kit I purchased
my PC is custom built with modern components and doesn't have a parallel port so I bought a pci addon card
in testing to see if I can turn output pins on and off with Mach I have no luck, I suspect I haven't got the port config setting correct
OS is Win7 32 bit, 2 screenshots from the device manager are attached
what should I set the port address to be and do you see any other items I should change?
Any Help Appreciated
Re: pci parallel port questions
« Reply #1 on: May 26, 2011, 06:22:34 PM »
I think you want EC00
Not sure about anything else, though.
« Reply #2 on: May 26, 2011, 06:41:27 PM »
bingo
you da man ;)
I thought you only type the last 3 digits but ec00 did the trick
thanks
« Reply #3 on: May 26, 2011, 07:26:23 PM »
I am having the same problem but my port address is no the same thru device manager my port is 2030-2037. i have changed this in mach 3 but still no luck.
« Reply #4 on: May 26, 2011, 07:46:41 PM »
can you post screen shots like I did?
a picture is worth, well, you know what I mean :)
« Reply #5 on: May 26, 2011, 07:47:31 PM »
If you entered 2030 and it doesn't work, I don't know what it could be. Sorry.
« Reply #6 on: May 26, 2011, 07:51:48 PM »
i not sure how to post the screen shots but it looks just like yours but it looks the same like yours but has 2030-2037 so i entered in mach3 0xc2030 but i still get no output. i am checking the direction pins and they stay at 0 no matter which direction i go
« Reply #7 on: May 26, 2011, 07:53:19 PM »
Just enter 2030, not 0xc2030
« Reply #8 on: May 26, 2011, 08:09:43 PM »
i tried that i still dont get a signal coming out of the port
« Reply #9 on: June 18, 2011, 09:01:30 AM »
i have the same issues with a lava parallel PCI card , their manual states "In standard installations of Windows 2000/XP and higher, the I/O address cannot
be changed to a legacy address" which are common 0278,  0378, etc   so mine is at DDFO and i can't get Mach3 to see it. any suggestions?
