Hello Guest it is November 07, 2026, 01:37:13 AM
Author Topic: The .set file format  (Read 101416 times)
« on: May 26, 2011, 01:15:34 PM »
Where can I find a full specification of the .set file format?
Re: The .set file format
« Reply #1 on: May 26, 2011, 03:41:00 PM »
« Reply #2 on: May 26, 2011, 04:50:57 PM »
Thank you very much!
« Reply #3 on: August 05, 2016, 09:17:29 PM »
Sorry for digging up an old topic, but I've tried to parse the format out per the Mach2 PDF posted above (from the archive.org historical cache, as the file 404'd on machsupport.com).  My parser, I believe, is following the original Mach2 spec, but it's still throwing some pretty wild errors when it encounters strings longer than 255 bytes, which shouldn't be possible according to the old spec.  It seems quite common, however, for newer screens to use > 256 chars for visual basic macros.
My question is, is there a later version of this document that explains how strings > 256 chars are handled?  is there an escape sequence?
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #4 on: August 13, 2016, 06:24:54 AM »
You may well have sorted this by now but if not...
AFAIK there is no later doc than the one you have. However many moons ago I reverse engineered the set file format in order to write my own screen designer.
So here you go. If the macro (or gcode) is less than 255 chars then the length byte indicates the length (as you know)
However if the length of the macro is 255 or greater then the length byte should be set to 255 and the following two bytes set to indicate the length. (hi, lo) IIRC.
« Reply #5 on: August 13, 2016, 09:23:44 AM »
Nope, I've been playing around with my new UC100 motion controller and a new breakout board design.  Was pleasantly surprised to see your reply, I added a few lines of code to my parser per your instructions, and it works like a charm!  Thanks again for the help!
Would you be able to share any details about it?  Is it something you've made public or will make public?  Just curious.  I'm writing a screen designer as well; not sure how much overlap or similarities we'll have, but I'd be interested in hearing what you've done.
« Reply #6 on: August 13, 2016, 09:33:58 AM »
What's the point of writing a screen designer when Mach3 is becoming obsolete, and there are already two other usable screen designers?
« Reply #7 on: August 13, 2016, 10:00:19 AM »
Does Newfangled Solutions give away free upgrades to Mach4?  Because I already own Mach3 (my license is 10+ years old), and I don't really feel the need to upgrade if it already works.
The screen designer is half of it.  I'm generating the skinned graphics from a script so that they don't look as ugly as the default skin, or the (even uglier) aftermarket skins.  So apples and oranges really.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #8 on: August 13, 2016, 10:41:29 AM »
No worries.
I never finished it to anywhere near releasable. See this thread http://www.machsupport.com/forum/index.php/topic,25574.0.html
As you can see, there was clearly no interest so I moved on to other things.
Offline GC
  •  1 1
« Reply #9 on: November 10, 2022, 08:04:22 AM »
