Hello Guest it is November 08, 2026, 02:53:12 AM
Author Topic: XBOX 360 PLUGIN Reset Button  (Read 10495 times)
Offline Helicopterjohn
  •  62 62
  • Seffner, Florida
    • Helicopterjohn.com
« on: May 26, 2011, 09:56:38 AM »
I purchased a used XBOX360 Controller that plugs into my USB Port.  I downloaded the associated plugin here at the ArtSoft website.
It is a wonderful addon and works as planned except for one thing.
Is there anyway to get the XBOX360 Controller to RESET the Mach3 Control (with the Auto Limit Override function activated) with a configured button i.e. X when a limit switch is triggered?
If I reach and activate a limit switch I can't use the assigned button i.e. X on the XBOX Controller to RESET the Mach3 Control.  If I use the button on the Mach3 Screen I am able to RESET the limit switch.  I have the Auto Limit Override function activated.
Any ideas or suggestions would be appreciated?
Thanks in advance for help.
John
Shopbot PRT 48 X 96  Gekco 203V drives, PMDX-126 Multi-Mode Breakout Board, PMDX-107 Isolated Speed Control, (2) Ea. PMDX-133 3-axis Daisy-Chainable Motherboard for Gekco 203V's, PMDX-2PARPCi Dual Parallel Port Card, Super PID Speed Controller, 2010 Screen Set, Solid State Relays for dust/coolant.
Re: XBOX 360 PLUGIN Reset Button
« Reply #1 on: May 26, 2011, 10:01:08 AM »
John go to "config" and "config plugins" and then config the controller and see if there is a option for that.
  •  62 62
  • Seffner, Florida
« Reply #2 on: May 26, 2011, 11:34:03 AM »
First, thanks for your input.
I currently have the (X) button on the XBOX360 set for the (RESET) option and it doesn't allow a reset by pushing that button on the XBOX360 controller when a Limit Switch is Triggered.
John
