Hello Guest it is October 26, 2026, 08:06:18 AM
Author Topic: Motors heating up  (Read 14510 times)
Motors heating up
« on: May 25, 2011, 12:48:06 PM »
Hi everyone.
I'm a new member, just bought TB6560 Driver and 3 Nema 17 steppers on e-bay for my first CNC.
Construction is nearly done, but I wanted to test the electronic.
I connected the driver to PC and started Mach3 mill.
I've configured it like the manual says (the one I got with the driver)
I've loaded roadrunner.tap G-code and started it.
The motors started turning, and everything looked fine.
I took about 6 minutes to complete.
But there's a problem.  The motors heat up really bad.
They are cold when they work, but when they stop they get hot pretty quickly.
In those 6 minutes they were cold, but when the program ended they heated up
in like 5 minutes so hot I couldn't touch them for more than half a second.
I use 24V 10A power supply but I've set voltage to 9V (checked with multimeter)
On the motors it says 11V
Motors are 17PM-K301-11V
They have 6 leads but I've connected 4 (4 connectors on the board for each axes)
I've connected leads like this
1 - A+
2 -
3 - A-
4 - B+
5 -
6 - B-
So 2 and 5 are not connected to anything.
All leads are colored gray, but I've checked short circuit with multimeter on A+ and A-
then B+ and B- to be sure they are of the same coil and they are.
How can I fix this?
I don't think a machine should work with motors so heated up.
Sve je moguće,
osim drvene peći koja gori i ne izgori
i prazne vriće koja stoji
- Prijatelj Max
Everything is possible
except wooden oven that burns and doesn't burn out
and empty bag that stays upright.
- Friend Max
Re: Motors heating up
« Reply #1 on: May 25, 2011, 12:59:31 PM »
Oh and one more thing.
I've just clicked "REF ALL HOME" in mach3 and Z axis motor started turning, others were still but had a good hold torque. I left it to turn for a few minutes and it remained completely cool but other two started getting warmer. While it was turning I've checked voltages between A+ and A- then B+ and B- on each motor.
Those two that weren't turning had 8V between A+ and A- and 8V between B+ and B-, but Z axis motor that was turning showed 0V on all.
I've set current setting on 25% (lowest) and decay mode on SLOW on the driver dip setting board
Micro step setting is 1
« Last Edit: May 25, 2011, 01:09:18 PM by CNC Doktor »
Sve je moguće,
- Prijatelj Max
- Friend Max
« Reply #2 on: May 25, 2011, 02:23:19 PM »
Did you purchase the "optional" step current board so you could reduce the current.
Post you manuals for the driver and board.
« Reply #3 on: May 25, 2011, 02:44:32 PM »
No.
There are dip switches on the controller board that are used to regulate current.
Sve je moguće,
- Prijatelj Max
- Friend Max
« Reply #4 on: May 25, 2011, 05:34:49 PM »
Current may still be to high for the motors even at 25%. They are realy small steppers.
« Reply #5 on: June 23, 2011, 06:30:58 AM »
THX Rich.
You were right. The current is too high.
But I bought 2 stronger motors (1.2 Nm) with higher current rating and now it seem that the smaller motor isn't heating up anymore, nether are 2 new motors.
Problem solved.
Sve je moguće,
- Prijatelj Max
- Friend Max
