Hello Guest it is November 09, 2026, 05:55:42 AM
Author Topic: Remote readout  (Read 12630 times)
Remote readout
« on: May 20, 2011, 12:12:16 PM »
Hi All, I have been searching for a pendant and have finally bought one. during the process I saw the ones with the LCD read out and thought it was a good idea but I really don't want it on the pendant but mounted in a box and mounted above the mill. So my question is how would I build a remote LCD for the DRO`s ? Is there a kit or instructions on how to build one?? Thanks for any help you can throw my way.
"Gravity, its not just a good idea its the law"
Re: Remote readout
« Reply #1 on: May 20, 2011, 05:59:11 PM »
Quite a few people have built panels and remote displayes using the ModIO and it's 20*4 LCD display.
If you have a look on the Mach3 support wiki, there is some great info of various ways to achieve what you want.
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach3_Pendants_links
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Customization_case_studies
The Pendant kit parts  I sell could also be used to make a panel rather than put it in the handheld enclosure. Rather than the whole kit, you could just purchase the parts you need. The Pendantkit  plugin will then allow you to use it to just be a remote display.
http://www.homanndesigns.com/store/index.php?main_page=product_info&cPath=15&products_id=74
Cheers,
Peter
Homann Designs
email: peter at homanndesigns.com
Re: Remote readout
« Reply #2 on: May 21, 2011, 02:26:50 PM »
Thank you for the info!!!  ;D ;D
Re: Remote readout
« Reply #3 on: May 22, 2011, 12:04:02 PM »
I looked through most of the info and the easyest way would be to get the ModIO and LCD but I am really looking for a USB solution, any ideas?
Re: Remote readout
« Reply #4 on: May 22, 2011, 07:10:22 PM »
Mach2 has VB functions for outputting to a serial port.  If you can find a USB display that looks to the system like a serial port, this would be an easy way to interface it, using a few lines of VB in a custom macropump.
Re: Remote readout
« Reply #5 on: May 23, 2011, 10:37:31 AM »
Thanks but i have never wrote a Macropump before and not sure how to do it.  ???
