Hello Guest it is November 12, 2026, 02:43:43 AM
Author Topic: Spindle speed display  (Read 9940 times)
« on: May 15, 2011, 09:07:37 PM »
Hi
I have a CNC router controlled with a Galil 2180 controler. Until recently I used a manual control to set the spindle speed. Recently I switched to using the servo control by setting up the (w) axis for the spindle control. This works fine.  The servo drive which I am using provides a 0 to 10v output as a speed feedback. This output is connected to the OEMDRO(1100) and the system reads this fine as well.  I would like to set up the spindle speed display to show the actual RPM value but I can only get it to display a value of 0 to 10. Is there a way to apply a scale to this displayed value to have a 0 to 25000 rpm value?
 Thanks for any help you may have.
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: Spindle speed display
« Reply #1 on: May 16, 2011, 07:17:20 AM »
You'll need to create a brain file and use a function to scale the inout to your rpm value. Brain files are covered in detail elsewhere on this forum.
Kenny
Having way too much fun! Something must surely be wrong.
