Hello Guest it is November 22, 2026, 12:13:43 PM
Author Topic: Left arrow key not responding/ spindle speed question  (Read 15292 times)
« on: May 15, 2011, 06:22:10 PM »
The left arrow key on my key board no longer jogs the machine, while the remaining right, up and down and page up and down work perfectly. I tried another key board with the same result. When I tab over to Jog Control I can jog in any direction including the left direction. Only the left arrow key while using the key board does not work?
I am using MasterCam to set up tools and tool paths. When I generate G Code  Mastercam only allows a max spindle speed of 2000 rpm even though I have requested a higher speed during set up. I can change the s number after generating the G Code  manually but shouldn’t always have to do that.  Somewhere there is a default that is limiting the spindle speed to 2000 in the G code.
Any help is appreciated.
Re: Left arrow key not responding/ spindle speed question
« Reply #1 on: May 15, 2011, 06:47:45 PM »
Look in Config, System hotkeys.  AND reset the hotkey value for the X- jog.
Most Cams set the spindle speed based on tool selection. Check your MC tool # for proper setup as to spindle speed.
Just a thought, (;-) TP
« Reply #2 on: May 15, 2011, 07:46:46 PM »
Thanks TP....
I checked the hot keys and the X- was at zero, I reset all of the hot keys and now the X + is not jogging and when pressed all the others become inactive until I reset again, reboot Mach 3 and then all work except X +.
When I select a tool in MasterCam that has a spindle speed in excess of 2000 I still only get s2000 in the G code.
« Reply #3 on: May 15, 2011, 07:57:19 PM »
Reset them all then do a save file.
The MC sounds like  a post problem it is not setting the proper speed based on the tool# info
« Reply #4 on: May 15, 2011, 08:33:56 PM »
Tried again and not sure where the save file function is.....only find save settings under config and that has not worked....still have the same issue and all the codes seem to be correct.
Sorry for being the dumbest guy on the forum!
« Reply #5 on: May 16, 2011, 05:37:46 AM »
can you attach your xml please.
« Reply #6 on: May 16, 2011, 09:46:50 AM »
XML file attached...is this what you are looking for?
« Reply #7 on: May 16, 2011, 09:55:59 AM »
Ok think your problem is you have the Code Window set to the same HotKey as the X++, change that and hopefully the arrows will work.
Its on the SystemHotkeys page as well.
