Hello Guest it is November 24, 2026, 06:10:43 PM
Author Topic: AutoProjection of toolphath on a virtual surface under mach3  (Read 9032 times)
Offline rdpdo
  •  12 12
hello,
Currently, for milling a non flat surface, I do probing on my non flat surface with a plugin, that give me XYZ file. Then, I import it into Solidworks for creating a surface. Under mastercam, i use the function PROJECT to project the ideal toolpath on my surface created uner solidworks and I use the result to mill the non flat surface under mach3.
That works perfectly.
But is there a way to make mach3 automaticly project a toolpath on the probing result of the non flat surface, that is to say no using solidworks never mastercam project function ?
Thanks you for your help. Regards.
PS : Or perhaps there is a plugin for doing this...
« Last Edit: May 12, 2011, 02:55:29 AM by rdpdo »
Re: AutoProjection of toolphath on a virtual surface under mach3
« Reply #1 on: May 12, 2011, 06:34:07 PM »
I don't think so (;-)
