Hello Guest it is October 21, 2026, 03:30:48 AM
Author Topic: O-Ring grove with a side cutter?  (Read 10200 times)
« on: May 10, 2011, 02:23:11 PM »
Does anyone know how I could use the conversational programing to cut an O-ring grove around a stand up vertical post using a woodruff key cutter. I tried the thread milling with a zero lead but that didn't seem to work.
Fred
Re: O-Ring grove with a side cutter?
« Reply #1 on: May 10, 2011, 03:16:07 PM »
I don't know of any outside groove wizard BUT the Gcode is fairly easy to work out.
Sample Code for cutting a groove outside on a boss
F100
G0X0Y0Z1.000      (center over the boss)
G1 X2.4                   (Move out to a clear position Boss Radius + tool radius + clearance)
Z-.5                          (lowerZ to cut height)
G3 X1.4  Y0 R.5      (Move in to depth of cut for oring groove using arc leadin)
G2 X-1.4 Y0 R1.4    ( cut a circle in two parts)
      X1.4 Y0 R1.4
G3 X2.4 Y0 R.5      (Move back out to a clearance position using arc leadout)
G0 Z1.000                      ( Raise Z to a safe height)
X0 Y0                        (Move back to boss center)
M30
Just a thought (;-)TP
« Reply #2 on: May 11, 2011, 09:27:59 AM »
BR549
Thanks this will work. I only need to plug in the numbers.
