Hello
Guest
it is
November 24, 2026, 06:10:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
problem setup mach3 under g540
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: problem setup mach3 under g540 (Read 8758 times)
komar1970
111
on:
May 10, 2011, 09:05:32 AM »
I have a problem with cutting on my machine
I give an example driving machine
original distance from the project
Y AXIS 85.80mm dimension after cut 86.57mm
X AXIS 120MM dimension after cut 121.20mm
can you tell my wath problem i have
Logged
Tweakie.CNC
9,378
Super Kitty
Re: problem setup mach3 under g540
Reply #1 on:
May 10, 2011, 10:13:05 AM »
Have you checked that your steps per unit are correct. Al's calculator is here
http://www.machsupport.com/forum/index.php/topic,16315.msg110286.html#msg110286
Logged
Print
Pages:
1
Go Up
« previous
next »
