Hello
Guest
it is
November 13, 2026, 10:57:32 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Z axis zero
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z axis zero (Read 10697 times)
GVP
7
Z axis zero
on:
November 28, 2006, 10:14:06 AM »
Hello,
Using Mach 3.
I'm sure it's something obvious but....
If we rout several copies of the same item, the zero axis does not appear to stay at the same reading between copies - is this correct behaviour? It means we have to zero the Z axis for each copy (we have a zero plate on the router)
I'm a bit of a noob, so is this how it should be?
Thanks!
Chip
2,055
Gainesville Florida USA
Re: Z axis zero
Reply #1 on:
November 28, 2006, 10:40:19 AM »
Hi, GVP
If it's stepper motors and losing steps on Z-UP (each part, deeper cut) Reduce the Velocity and Acceleration in Motor Tuning Z axis,or
reduce F speed for Z.
More Info would help
See if this Helps, Chip
Print
Pages:
1
Go Up
« previous
next »
