Hello Guest it is November 14, 2026, 02:35:20 PM
Author Topic: Having trouble, need help with inches-mm  (Read 11660 times)
« on: May 08, 2011, 04:38:40 PM »
I've just got my machine, and was giving Mach3 and everything a test, and I'm stuck in mm and need to get to inches...I may just be overlooking something, but can't figure out how to switch...?
Re: Having trouble, need help with inches-mm
« Reply #1 on: May 08, 2011, 05:08:16 PM »
At the top of the screen, config then select native units. You will need to recheck all your motor setting I think.
« Reply #2 on: May 08, 2011, 05:19:53 PM »
What will it do to the motor settings?
« Reply #3 on: May 08, 2011, 06:11:39 PM »
I mean may, I only know that it is set once and not ment to be changed after. The g20/g21 comands will switch the machine between mm and inches once you get it set up.
You could try entering this for a test
G20(inch mode)
G90(absolut positioning)
F5(feed rate)
X 1(moves x to 1)
« Reply #4 on: May 08, 2011, 07:12:20 PM »
thats: g1 X 1(moves x to 1 at current feed rate)
