Hello Guest it is November 24, 2026, 02:06:07 PM
Author Topic: E-Stop LED Output/Pin Output  (Read 11376 times)
« on: May 07, 2011, 05:25:04 PM »
Is it possible to have Mach toggle an output Port Pin on and off when in E-Stop??
 I want to add a large red light to the Mill that will run off a solid state relay. If there is a way to have Mach turn on or off an output pin, i can find a way to do it. It would be extra nice if it would "flash" the pin but i would be happy with just on or off LOL!
Zc
Re: E-Stop LED Output/Pin Output
« Reply #1 on: May 07, 2011, 05:26:47 PM »
How about using one of the enable outputs?
« Reply #2 on: May 07, 2011, 05:30:19 PM »
OOOOHHHH...hmmm yeah that would work. good idea! good idea! I hadn't thought about that.
« Reply #3 on: May 07, 2011, 05:34:30 PM »
I think all outputs switch off when Mach is in E-Stop but the benefit of the enables is they will switch on without any additional means when Mach comes out of reset, so they sound like the ideal way. Also a NC relay would work the light perfectly as Mach would open the relay thus switching the light off when not in E-Stop. Flashing would require some additional components but I think you get flashing LEDs which may be worth looking into.
« Reply #4 on: May 07, 2011, 05:39:53 PM »
I will play with this a bit.
 I have some nice 25 amp Solid state relays with LED inputs that can run of the printer port directly. it wouldn't flash but it would light up a 60watt bulb just fine. but i could also use the port to trigger a 555 timer and a SSR and then i could flash the bulb.
