Hello Guest it is November 11, 2026, 07:22:54 PM
Author Topic: Setup To Change Manual Jog Speed  (Read 23531 times)
Offline GeorgeRace
  •  53 53
  • My Home Built Airplane
    • Race Consulting
« on: May 06, 2011, 02:27:47 PM »
I want to be able to change the jog speed that the mill moves when pressing any of the axis position keys.  This will allow me to do manual control of the axis speed when doing manual milling with the keyboard arrow keys. (Just like being able to crank the axis manually)
I put a Slow Jog %DRO on the screen, it is linked to OEM 3 function
I put a Slow Jog Down button on the screen, it is linked to OEM 112
I put a Slow Jog Up button on the screen, it is linked to OEM 111.
I would like those functions to work just like they do on the "Pop Out" jog pendant screen.
When I select the %DRO window and put in a new value, it puts the value in the X Axis DRO.
When I select either the slow up or slow down button, it toggles the Start button.
I am really doing something wrong here and can't seem to figure it out.
Help will be greatly appreciated,
George
Check out my home page
http://www.mrrace.com
Re: Setup To Change Manual Jog Speed
« Reply #1 on: May 07, 2011, 06:22:11 AM »
Hi George
if found a bug in version V1.48 which sets internal a wrong OEM-code. Until I've fixed that, I suggest you use version V1.47. For those, not having that version, please send me a email and I send you V1.47.  Sorry for that inconvenience.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline GeorgeRace
  •  53 53
    • Race Consulting
« Reply #2 on: May 07, 2011, 06:56:12 AM »
Hi Klaus:
Thanks for the reply.  This morning I was going to install an older version and see if I still had the problem.
I will uninstall 1.48 and go back to a previous version.
George Race
« Reply #3 on: May 07, 2011, 11:26:46 AM »
Hi George,
you can download the updated version V1.49. If you find something strange, or have questions, please let me know.
Klaus
Offline GeorgeRace
  •  53 53
    • Race Consulting
« Reply #4 on: May 07, 2011, 07:14:19 PM »
Hi Klaus:
I have installed 1.49 and it does seem to be working just fine.
The 1.48 version locked up two different computers as well as not working properly.  Sure glad you got rid of that one and have replaced it with the new and improved version.
If 1.49 throws any errors I will get on here and let you know.
Thanks for the help and all the work you do on this very fine program,
George
