Hello Guest it is November 22, 2026, 10:13:31 AM
Author Topic: nidet help  (Read 21243 times)
nidet help
« on: May 05, 2011, 07:59:27 PM »
Please give me some advices how to set the motor steps in MACH3
I mean if i open mach3 i go to setting and set seteps per unit
You can choose at this point, Y, Z, X, or A axis
I do not know how far to move up axis
I work in mm
and I use for that Digital Indicator
For example, when you write a 5mm machine is travels 4.987mm
a few times Digital Indicator shows the machine is moved 5mm
it should be a good setting steps per unit
For example, ball screw is pinch 4mm the driver is 10 micro steps
the motors motors 200 steps
So we'll take the motors 200 steps multiply that by the drives 10 micro step.
(200 X 10 = 2000)
The drive needs 2000 pulses (or steps) to turn the screw one revolution thus
making the axis
move 4mm. So now we take those 2000 steps and divide by the pitch of the screw,
which is 4.
(2000 / 4 = 500). In other words we need 500 steps to move one unit or mm.
but the setting in Mach3 shows me 513 steps This maybe the problem is backlash
problem bacause it shows 513 steps .but the worst thing is if you set the
Stepps motor to travels 5mm and the machine is moving 5mm everything is ok
but how do you tell the machine to go 200mm, machine is travels
197.499mm can you tell my woth problem it is
  •  9,378 9,378
Re: nidet help
« Reply #1 on: May 06, 2011, 12:59:43 AM »
Komar,
Steps per unit are a mechanical thing and your calculations are correct for the information you have given therefore you should be entering 500 as the steps per unit.
Offline kf2qd
  •  157 157
Re: nidet help
« Reply #2 on: May 06, 2011, 03:29:15 PM »
Several things can account for this error - slop in some portion of the machine, the screws aren't as accurate as they could be, something is slipping... Make sure the mechanical part of the machine is good before you beat on the software side, otherwise you will be forever chasing a number that doesn't exist in software because the hardwae is nor reliable.
you might try putting 519.4963 and see how that affects shorter moves, it should take care of things for the 200mm move.
Re: nidet help
« Reply #3 on: May 06, 2011, 08:03:03 PM »
I work in mm. Mach3 is set to mm. rhinocam is set to mm.
 I do not understand one thing?. when the machine is running on the computer screen! in  the Mach3, I see inch not mm  what to do to change this
  •  9,378 9,378
Re: nidet help
« Reply #4 on: May 07, 2011, 03:04:32 AM »
Perhaps your GCode contains a G20.
Re: nidet help
« Reply #5 on: May 07, 2011, 03:33:27 AM »
Can you attach the code and also the xml you are using please.
Re: nidet help
« Reply #6 on: May 07, 2011, 06:56:31 AM »
- <profile>
- <Preferences>
  <m_SafeZ>0.</m_SafeZ>
  <CVUseAngle>0</CVUseAngle>
  <CVDegrees>0.</CVDegrees>
  <IgnoreMacros>0</IgnoreMacros>
  <ZBar>1</ZBar>
  <ROTSOFT>1</ROTSOFT>
  <PROBETLO>0</PROBETLO>
  <SlaveHome>0</SlaveHome>
  <JogHeat>0</JogHeat>
  <KeyClick>0</KeyClick>
  <THC5>0</THC5>
  <SpinInc>100</SpinInc>
  <M30SpinOff>1</M30SpinOff>
  <AutoCalcs>0</AutoCalcs>
  <Boxed>1</Boxed>
  <SafeZStop>0</SafeZStop>
  <SafeZType>0</SafeZType>
  <UseDiam>1</UseDiam>
  <ToolLines>0</ToolLines>
  <NURBS>1</NURBS>
  <ToolPersist>0</ToolPersist>
  <KeepRef>0</KeepRef>
  <TurnRevArc>1</TurnRevArc>
  <TORCHVON>0</TORCHVON>
  <TORCHVOLTS>0</TORCHVOLTS>
  <HWSAFE>1</HWSAFE>
  <ShortRot>0</ShortRot>
  <LookAhead>20</LookAhead>
  <WatchDog>1</WatchDog>
  <Plane>0</Plane>
  <MPG1>0</MPG1>
  <MPG2>0</MPG2>
  <HotKeysPersist>0</HotKeysPersist>
  <HoldInput1>0</HoldInput1>
  <M3s>173</M3s>
  <HiRes>0</HiRes>
  <UseCR>0</UseCR>
  <DelinChar>12</DelinChar>
  <PlasmaHome>0</PlasmaHome>
  <Rot360>0</Rot360>
  <Homann>0</Homann>
  <UseSLS>0</UseSLS>
  <UDP>0</UDP>
  <DROFont>Arial</DROFont>
  <LabelFont>Arial</LabelFont>
  <CodeFont>Arial</CodeFont>
  <ButtonFont>Arial</ButtonFont>
  <Dist0>6.4e+005</Dist0>
  <Dist1>8.e+005</Dist1>
  <Dist2>1.5e+005</Dist2>
  <Dist3>52</Dist3>
  <Dist4>0.</Dist4>
  <Dist5>0.</Dist5>
  <OverMode2>0</OverMode2>
  <BitPack1>0</BitPack1>
  <BitPack1Reg>16</BitPack1Reg>
  <BitPackOut>0</BitPackOut>
  <BitPackOutReg>16</BitPackOutReg>
  <LaserPort>1</LaserPort>
  <LaserBaud>9600</LaserBaud>
  <LaserStops>1</LaserStops>
  <LaserData>1</LaserData>
  <LaserInit>></LaserInit>
  <LaserCommand>></LaserCommand>
  <MacroPump>0</MacroPump>
  <PierceDelay>1.</PierceDelay>
  <VelMode>0</VelMode>
  <VelPer1>5.</VelPer1>
  <VelPer2>5.</VelPer2>
  <VelPer3>5.</VelPer3>
  <TouchX>0.</TouchX>
  <G20X>0.</G20X>
  <G20Y>0.</G20Y>
  <G20Z>0.</G20Z>
  <G20A>0.</G20A>
  <G20B>0.</G20B>
  <G20C>0.</G20C>
  <MPGFeed>1.e+002</MPGFeed>
  <ModSpindleCal>1.638e+004</ModSpindleCal>
  <ModSpindleOn>0</ModSpindleOn>
  <ModSpindleReg>64</ModSpindleReg>
  <ShuttleAccel>512000</ShuttleAccel>
  <Flash>1</Flash>
  <ImmediateOff>0</ImmediateOff>
  <UseSafeZ>0</UseSafeZ>
  <AdvancedComp>1</AdvancedComp>
  <TorchOff>0</TorchOff>
  <LaserStandby>0</LaserStandby>
  <RaiseLower>0</RaiseLower>
  <OEMDUAL>0</OEMDUAL>
  <IncBuffer>5</IncBuffer>
  <Formula0>x</Formula0>
  <Formula1>y</Formula1>
  <Formula2>z</Formula2>
  <Formula3>a</Formula3>
  <Formula4>b</Formula4>
  <Formula5>c</Formula5>
  <Formular>0</Formular>
  <PanelOut>350</PanelOut>
  <nModBusReg>0</nModBusReg>
  <ModBusRegOn>0</ModBusRegOn>
  <Tool>0</Tool>
  <Sherline>0</Sherline>
  <ToolPost>1</ToolPost>
  <RapidOverRide>0</RapidOverRide>
  <XCLength>1.3e+003</XCLength>
  <YCLength>1.3e+003</YCLength>
  <ZCLength>1.3e+003</ZCLength>
  <ToolPostOffset>0.</ToolPostOffset>
  <FrontRear>0.</FrontRear>
  <OEM1>-1</OEM1>
  <OEM2>-1</OEM2>
  <OEM3>-1</OEM3>
  <OEM4>-1</OEM4>
  <OEM5>-1</OEM5>
  <OEM6>-1</OEM6>
  <OEM7>-1</OEM7>
  <OEM8>-1</OEM8>
  <OEM9>-1</OEM9>
  <OEM10>-1</OEM10>
  <OEM11>-1</OEM11>
  <OEM12>-1</OEM12>
  <OEM13>-1</OEM13>
  <OEM14>-1</OEM14>
  <OEM15>-1</OEM15>
  <MPGVel0>1.e+002</MPGVel0>
  <MPGVel1>1.e+002</MPGVel1>
  <MPGVel2>1.e+002</MPGVel2>
  <MPGVel3>1.e+002</MPGVel3>
  <MPGVel4>1.e+002</MPGVel4>
  <MPGVel5>1.e+002</MPGVel5>
  <MPGVel6>1.e+002</MPGVel6>
  <ByPassFeed>1.e+003</ByPassFeed>
  <XMapOn>0</XMapOn>
  <YMapOn>0</YMapOn>
  <ZMapOn>0</ZMapOn>
  <SecondsOn>980419</SecondsOn>
  <SerialType>0</SerialType>
  <SpinAverage>0</SpinAverage>
  <Dig4Axis>0</Dig4Axis>
  <DigLetter>0</DigLetter>
  <CutType>0</CutType>
  <InfeedType>0</InfeedType>
  <LastWizard>None</LastWizard>
  <Z25D>0</Z25D>
  <ModBus>0</ModBus>
  <ChargeAlwaysOn>0</ChargeAlwaysOn>
  <ToolFlip>0</ToolFlip>
  <SpinCCW>8</SpinCCW>
  <SpinCW>7</SpinCW>
  <Flood>10</Flood>
  <Mist>9</Mist>
  <SpinActual>0</SpinActual>
  <SpinDelayCW>1.</SpinDelayCW>
  <SpinDelayCCW>1.</SpinDelayCCW>
  <SpinDownCW>1.</SpinDownCW>
  <SpinDownCCW>1.</SpinDownCCW>
  <StockSize>50</StockSize>
  <ShowSolid>0</ShowSolid>
  <RapidFeed>1.e+003</RapidFeed>
  <MatRed>0.</MatRed>
  <MatGreen>0.1</MatGreen>
  <MatBlue>0.1</MatBlue>
  <SpinP>0.25</SpinP>
  <SpinI>1.</SpinI>
  <SpinD>0.3</SpinD>
  <SpinClosed>0</SpinClosed>
  <MinPerPass>0.1</MinPerPass>
  <NoSpindle>0</NoSpindle>
  <NoFlood>0</NoFlood>
  <PWMin>0</PWMin>
  <PULLEY>3</PULLEY>
  <PWM>1</PWM>
  <SPEED1>25000</SPEED1>
  <LSPEED1>0</LSPEED1>
  <SPINREV1>0</SPINREV1>
  <SPINRATIO1>1.</SPINRATIO1>
  <SPEED2>25000</SPEED2>
  <LSPEED2>0</LSPEED2>
  <SPINREV2>0</SPINREV2>
  <SPINRATIO2>1.</SPINRATIO2>
  <SPEED3>25000</SPEED3>
  <LSPEED3>0</LSPEED3>
  <SPINREV3>0</SPINREV3>
  <SPINRATIO3>1.</SPINRATIO3>
  <SPEED4>25000</SPEED4>
  <LSPEED4>0</LSPEED4>
  <SPINREV4>0</SPINREV4>
  <SPINRATIO4>1.</SPINRATIO4>
  <SPEED5>25000</SPEED5>
  <LSPEED5>0</LSPEED5>
  <SPINREV5>0</SPINREV5>
  <SPINRATIO5>1.</SPINRATIO5>
  <SPEED6>25000</SPEED6>
  <LSPEED6>0</LSPEED6>
  <SPINREV6>0</SPINREV6>
  <SPINRATIO6>1.</SPINRATIO6>
  <SPEED7>25000</SPEED7>
  <LSPEED7>0</LSPEED7>
  <SPINREV7>0</SPINREV7>
  <SPINRATIO7>1.</SPINRATIO7>
  <SPEED8>25000</SPEED8>
  <LSPEED8>0</LSPEED8>
  <SPINREV8>0</SPINREV8>
  <SPINRATIO8>1.</SPINRATIO8>
  <SPEED9>25000</SPEED9>
  <LSPEED9>0</LSPEED9>
  <SPINREV9>0</SPINREV9>
  <SPINRATIO9>1.</SPINRATIO9>
  <SPEED10>25000</SPEED10>
  <LSPEED10>0</LSPEED10>
  <SPINREV10>0</SPINREV10>
  <SPINRATIO10>1.</SPINRATIO10>
  <SPEED11>25000</SPEED11>
  <LSPEED11>0</LSPEED11>
  <SPINREV11>0</SPINREV11>
  <SPINRATIO11>1.</SPINRATIO11>
  <SPEED12>25000</SPEED12>
  <LSPEED12>0</LSPEED12>
  <SPINREV12>0</SPINREV12>
  <SPINRATIO12>1.</SPINRATIO12>
  <SPEED13>25000</SPEED13>
  <LSPEED13>0</LSPEED13>
  <SPINREV13>0</SPINREV13>
  <SPINRATIO13>1.</SPINRATIO13>
  <SPEED14>25000</SPEED14>
  <LSPEED14>0</LSPEED14>
  <SPINREV14>0</SPINREV14>
  <SPINRATIO14>1.</SPINRATIO14>
  <SPEED15>25000</SPEED15>
  <LSPEED15>0</LSPEED15>
  <SPINREV15>0</SPINREV15>
  <SPINRATIO15>1.</SPINRATIO15>
  <SPEED16>25000</SPEED16>
  <LSPEED16>0</LSPEED16>
  <SPINREV16>0</SPINREV16>
  <SPINRATIO16>1.</SPINRATIO16>
  <SPEED17>25000</SPEED17>
  <LSPEED17>0</LSPEED17>
  <SPINREV17>0</SPINREV17>
  <SPINRATIO17>1.</SPINRATIO17>
  <SPEED18>25000</SPEED18>
  <LSPEED18>0</LSPEED18>
  <SPINREV18>0</SPINREV18>
  <SPINRATIO18>1.</SPINRATIO18>
  <SPEED19>25000</SPEED19>
  <LSPEED19>0</LSPEED19>
  <SPINREV19>0</SPINREV19>
  <SPINRATIO19>1.</SPINRATIO19>
  <SPEED20>25000</SPEED20>
  <LSPEED20>0</LSPEED20>
  <SPINREV20>0</SPINREV20>
  <SPINRATIO20>1.</SPINRATIO20>
  <SPEED21>25000</SPEED21>
  <LSPEED21>0</LSPEED21>
  <SPINREV21>0</SPINREV21>
  <SPINRATIO21>1.</SPINRATIO21>
  <SPEED22>25000</SPEED22>
  <LSPEED22>0</LSPEED22>
  <SPINREV22>0</SPINREV22>
  <SPINRATIO22>1.</SPINRATIO22>
  <SPEED23>25000</SPEED23>
  <LSPEED23>0</LSPEED23>
  <SPINREV23>0</SPINREV23>
  <SPINRATIO23>1.</SPINRATIO23>
  <SPEED24>25000</SPEED24>
  <LSPEED24>0</LSPEED24>
  <SPINREV24>0</SPINREV24>
  <SPINRATIO24>1.</SPINRATIO24>
  <SPEED25>25000</SPEED25>
  <LSPEED25>0</LSPEED25>
  <SPINREV25>0</SPINREV25>
  <SPINRATIO25>1.</SPINRATIO25>
  <RefSpeed0>20</RefSpeed0>
  <RefSpeed1>20</RefSpeed1>
  <RefSpeed2>20</RefSpeed2>
  <RefSpeed3>20</RefSpeed3>
  <RefSpeed4>20</RefSpeed4>
  <RefSpeed5>20</RefSpeed5>
  <M0SoftRamp>1.</M0SoftRamp>
  <M1SoftRamp>1.</M1SoftRamp>
  <M2SoftRamp>1.</M2SoftRamp>
  <M3SoftRamp>1.</M3SoftRamp>
  <M4SoftRamp>1.</M4SoftRamp>
  <M5SoftRamp>1.</M5SoftRamp>
  <FeedInc>5.</FeedInc>
  <DepthLastPass>0.</DepthLastPass>
  <InFeed>29.5</InFeed>
  <Spring>1.</Spring>
  <MinDepth>1.e-003</MinDepth>
  <XClear>0.1</XClear>
  <ZClear>0.1</ZClear>
  <CutDepth>0.1</CutDepth>
  <Chamfer>0.</Chamfer>
  <DepthFirstPass>0.1</DepthFirstPass>
  <M0Max>100.</M0Max>
  <M1Max>100.</M1Max>
  <M2Max>100.</M2Max>
  <M3Max>100.</M3Max>
  <M4Max>100.</M4Max>
  <M5Max>100.</M5Max>
  <M0Min>-100.</M0Min>
  <M1Min>-100.</M1Min>
  <M2Min>-100.</M2Min>
  <M3Min>-100.</M3Min>
  <M4Min>-100.</M4Min>
  <M5Min>-100.</M5Min>
  <M0Neg>0</M0Neg>
  <M1Neg>0</M1Neg>
  <M2Neg>0</M2Neg>
  <M3Neg>0</M3Neg>
  <M4Neg>0</M4Neg>
  <M5Neg>0</M5Neg>
  <M0Rev>0</M0Rev>
  <M1Rev>0</M1Rev>
  <M2Rev>0</M2Rev>
  <M3Rev>0</M3Rev>
  <M4Rev>0</M4Rev>
  <M5Rev>0</M5Rev>
  <M6Rev>0</M6Rev>
  <MaxNC10>0</MaxNC10>
  <OffPersist>0</OffPersist>
  <Diameter>0</Diameter>
  <OffDialogs>0</OffDialogs>
Re: nidet help
« Reply #7 on: May 07, 2011, 06:57:25 AM »
  <G54Back>0</G54Back>
  <GougeCheck>1</GougeCheck>
  <AxisToMotor0>0</AxisToMotor0>
  <AxisToMotor1>1</AxisToMotor1>
  <AxisToMotor2>2</AxisToMotor2>
  <AxisToMotor3>3</AxisToMotor3>
  <AxisToMotor4>4</AxisToMotor4>
  <AxisToMotor5>5</AxisToMotor5>
  <AxisToMotor6>6</AxisToMotor6>
  <JogActive>1</JogActive>
  <BLState0>0</BLState0>
  <BLState1>1</BLState1>
  <BLState2>0</BLState2>
  <BLState3>0</BLState3>
  <BLState4>0</BLState4>
  <BLState5>0</BLState5>
  <SlowMode>0</SlowMode>
  <JogPersist>1</JogPersist>
  <ToolRotations>1</ToolRotations>
  <SoftLimit>0</SoftLimit>
  <JogMode>0</JogMode>
  <EncJogAxis1>0</EncJogAxis1>
  <EncJogAxis2>1</EncJogAxis2>
  <EncJogAxis3>2</EncJogAxis3>
  <TaperRatio>1.</TaperRatio>
  <XStart>0</XStart>
  <YStart>0</YStart>
  <ZStart>0</ZStart>
  <AStart>0</AStart>
  <BStart>0</BStart>
  <CStart>0</CStart>
  <OVSpinInc>10</OVSpinInc>
  <Enc0>0.</Enc0>
  <Enc1>0.</Enc1>
  <Enc2>0.</Enc2>
  <Enc3>0.</Enc3>
  <TangentalControl>0</TangentalControl>
  <BaudRate>9600</BaudRate>
  <ComPort>1</ComPort>
  <NoPlunge>0</NoPlunge>
  <PlungeLimit>60</PlungeLimit>
  <AutoTool>0</AutoTool>
  <AutoSpindle>0</AutoSpindle>
  <LaserMode>0</LaserMode>
  <FeedMode>0</FeedMode>
  <AAngular>1</AAngular>
  <BAngular>1</BAngular>
  <CAngular>1</CAngular>
  <OriginSphere>0</OriginSphere>
  <m_3dCompass>1</m_3dCompass>
  <Boundries>0</Boundries>
  <ToolPosition>1</ToolPosition>
  <AParallel>0</AParallel>
  <ZINHPersist>0</ZINHPersist>
  <OVPersist>1</OVPersist>
  <BacklashOn>0</BacklashOn>
  <ThrottleFunc>2</ThrottleFunc>
  <JoyOn>0</JoyOn>
  <PWMBase>5000</PWMBase>
  <JogSpeed>95.</JogSpeed>
  <G73PullBack>0.1</G73PullBack>
  <CVFeedOn>0</CVFeedOn>
  <CVFeedRate>1.</CVFeedRate>
  <AtoX>0.</AtoX>
  <AtoY>0.</AtoY>
  <AtoZ>0.</AtoZ>
  <OEMDRO0>0.</OEMDRO0>
  <OEMLED0>0</OEMLED0>
  <OEMDRO1>0.</OEMDRO1>
  <OEMLED1>0</OEMLED1>
  <OEMDRO2>0.</OEMDRO2>
  <OEMLED2>0</OEMLED2>
  <OEMDRO3>0.</OEMDRO3>
  <OEMLED3>0</OEMLED3>
  <OEMDRO4>0.</OEMDRO4>
  <OEMLED4>0</OEMLED4>
  <OEMDRO5>0.</OEMDRO5>
  <OEMLED5>0</OEMLED5>
  <OEMDRO6>0.</OEMDRO6>
  <OEMLED6>0</OEMLED6>
  <OEMDRO7>0.</OEMDRO7>
  <OEMLED7>0</OEMLED7>
  <OEMDRO8>0.</OEMDRO8>
  <OEMLED8>0</OEMLED8>
  <OEMDRO9>0.</OEMDRO9>
  <OEMLED9>0</OEMLED9>
  <OEMDRO10>0.</OEMDRO10>
  <OEMLED10>0</OEMLED10>
  <OEMDRO11>0.</OEMDRO11>
  <OEMLED11>0</OEMLED11>
  <OEMDRO12>0.</OEMDRO12>
  <OEMLED12>0</OEMLED12>
  <OEMDRO13>0.</OEMDRO13>
  <OEMLED13>0</OEMLED13>
  <OEMDRO14>0.</OEMDRO14>
  <OEMLED14>0</OEMLED14>
  <OEMDRO15>0.</OEMDRO15>
  <OEMLED15>0</OEMLED15>
  <OEMDRO16>0.</OEMDRO16>
  <OEMLED16>0</OEMLED16>
  <OEMDRO17>0.</OEMDRO17>
  <OEMLED17>0</OEMLED17>
  <OEMDRO18>0.</OEMDRO18>
  <OEMLED18>0</OEMLED18>
  <OEMDRO19>0.</OEMDRO19>
  <OEMLED19>0</OEMLED19>
  <OEMDRO20>0.</OEMDRO20>
  <OEMLED20>0</OEMLED20>
  <OEMDRO21>0.</OEMDRO21>
  <OEMLED21>0</OEMLED21>
  <OEMDRO22>0.</OEMDRO22>
  <OEMLED22>0</OEMLED22>
  <OEMDRO23>0.</OEMDRO23>
  <OEMLED23>0</OEMLED23>
  <OEMDRO24>0.</OEMDRO24>
  <OEMLED24>0</OEMLED24>
  <OEMDRO25>0.</OEMDRO25>
  <OEMLED25>0</OEMLED25>
  <OEMDRO26>0.</OEMDRO26>
  <OEMLED26>0</OEMLED26>
  <OEMDRO27>0.</OEMDRO27>
  <OEMLED27>0</OEMLED27>
  <OEMDRO28>0.</OEMDRO28>
  <OEMLED28>0</OEMLED28>
  <OEMDRO29>0.</OEMDRO29>
  <OEMLED29>0</OEMLED29>
  <OEMDRO30>0.</OEMDRO30>
  <OEMLED30>0</OEMLED30>
  <OEMDRO31>0.</OEMDRO31>
  <OEMLED31>0</OEMLED31>
  <OEMDRO32>0.</OEMDRO32>
  <OEMLED32>0</OEMLED32>
  <OEMDRO33>0.</OEMDRO33>
  <OEMLED33>0</OEMLED33>
  <OEMDRO34>0.</OEMDRO34>
  <OEMLED34>0</OEMLED34>
  <OEMDRO35>0.</OEMDRO35>
  <OEMLED35>0</OEMLED35>
  <OEMDRO36>0.</OEMDRO36>
  <OEMLED36>0</OEMLED36>
  <OEMDRO37>0.</OEMDRO37>
  <OEMLED37>0</OEMLED37>
  <OEMDRO38>0.</OEMDRO38>
  <OEMLED38>0</OEMLED38>
  <OEMDRO39>0.</OEMDRO39>
  <OEMLED39>0</OEMLED39>
  <OEMDRO40>0.</OEMDRO40>
  <OEMLED40>0</OEMLED40>
  <OEMDRO41>0.</OEMDRO41>
  <OEMLED41>0</OEMLED41>
  <OEMDRO42>0.</OEMDRO42>
  <OEMLED42>0</OEMLED42>
  <OEMDRO43>0.</OEMDRO43>
  <OEMLED43>0</OEMLED43>
  <OEMDRO44>0.</OEMDRO44>
  <OEMLED44>0</OEMLED44>
  <OEMDRO45>0.</OEMDRO45>
  <OEMLED45>0</OEMLED45>
  <OEMDRO46>0.</OEMDRO46>
  <OEMLED46>0</OEMLED46>
  <OEMDRO47>0.</OEMDRO47>
  <OEMLED47>0</OEMLED47>
  <OEMDRO48>0.</OEMDRO48>
  <OEMLED48>0</OEMLED48>
  <OEMDRO49>0.</OEMDRO49>
  <OEMLED49>0</OEMLED49>
  <OEMDRO50>0.</OEMDRO50>
  <OEMLED50>0</OEMLED50>
  <OEMDRO51>0.</OEMDRO51>
  <OEMLED51>0</OEMLED51>
  <OEMDRO52>0.</OEMDRO52>
  <OEMLED52>0</OEMLED52>
  <OEMDRO53>0.</OEMDRO53>
  <OEMLED53>0</OEMLED53>
  <OEMDRO54>0.</OEMDRO54>
  <OEMLED54>0</OEMLED54>
  <OEMDRO55>0.</OEMDRO55>
  <OEMLED55>0</OEMLED55>
  <OEMDRO56>0.</OEMDRO56>
  <OEMLED56>0</OEMLED56>
  <OEMDRO57>0.</OEMDRO57>
  <OEMLED57>0</OEMLED57>
  <OEMDRO58>0.</OEMDRO58>
  <OEMLED58>0</OEMLED58>
  <OEMDRO59>0.</OEMDRO59>
  <OEMLED59>0</OEMLED59>
  <OEMDRO60>0.</OEMDRO60>
  <OEMLED60>0</OEMLED60>
  <OEMDRO61>0.</OEMDRO61>
  <OEMLED61>0</OEMLED61>
  <OEMDRO62>0.</OEMDRO62>
  <OEMLED62>0</OEMLED62>
  <OEMDRO63>0.</OEMDRO63>
  <OEMLED63>0</OEMLED63>
  <OEMDRO64>0.</OEMDRO64>
  <OEMLED64>0</OEMLED64>
  <OEMDRO65>0.</OEMDRO65>
  <OEMLED65>0</OEMLED65>
  <OEMDRO66>0.</OEMDRO66>
  <OEMLED66>0</OEMLED66>
  <OEMDRO67>0.</OEMDRO67>
  <OEMLED67>0</OEMLED67>
  <OEMDRO68>0.</OEMDRO68>
  <OEMLED68>0</OEMLED68>
  <OEMDRO69>0.</OEMDRO69>
  <OEMLED69>0</OEMLED69>
  <OEMDRO70>0.</OEMDRO70>
  <OEMLED70>0</OEMLED70>
  <OEMDRO71>0.</OEMDRO71>
  <OEMLED71>0</OEMLED71>
  <OEMDRO72>0.</OEMDRO72>
  <OEMLED72>0</OEMLED72>
  <OEMDRO73>0.</OEMDRO73>
  <OEMLED73>0</OEMLED73>
  <OEMDRO74>0.</OEMDRO74>
  <OEMLED74>0</OEMLED74>
  <OEMDRO75>0.</OEMDRO75>
  <OEMLED75>0</OEMLED75>
  <OEMDRO76>0.</OEMDRO76>
  <OEMLED76>0</OEMLED76>
  <OEMDRO77>0.</OEMDRO77>
  <OEMLED77>0</OEMLED77>
  <OEMDRO78>0.</OEMDRO78>
  <OEMLED78>0</OEMLED78>
  <OEMDRO79>0.</OEMDRO79>
  <OEMLED79>0</OEMLED79>
  <OEMDRO80>0.</OEMDRO80>
  <OEMLED80>0</OEMLED80>
  <OEMDRO81>0.</OEMDRO81>
  <OEMLED81>0</OEMLED81>
  <OEMDRO82>0.</OEMDRO82>
  <OEMLED82>0</OEMLED82>
  <OEMDRO83>0.</OEMDRO83>
  <OEMLED83>0</OEMLED83>
  <OEMDRO84>0.</OEMDRO84>
  <OEMLED84>0</OEMLED84>
  <OEMDRO85>0.</OEMDRO85>
  <OEMLED85>0</OEMLED85>
  <OEMDRO86>0.</OEMDRO86>
  <OEMLED86>0</OEMLED86>
  <OEMDRO87>0.</OEMDRO87>
  <OEMLED87>0</OEMLED87>
  <OEMDRO88>0.</OEMDRO88>
  <OEMLED88>0</OEMLED88>
  <OEMDRO89>0.</OEMDRO89>
  <OEMLED89>0</OEMLED89>
  <OEMDRO90>0.</OEMDRO90>
  <OEMLED90>0</OEMLED90>
  <OEMDRO91>0.</OEMDRO91>
  <OEMLED91>0</OEMLED91>
  <OEMDRO92>0.</OEMDRO92>
  <OEMLED92>0</OEMLED92>
  <OEMDRO93>0.</OEMDRO93>
  <OEMLED93>0</OEMLED93>
  <OEMDRO94>0.</OEMDRO94>
  <OEMLED94>0</OEMLED94>
  <OEMDRO95>0.</OEMDRO95>
  <OEMLED95>0</OEMLED95>
  <OEMDRO96>0.</OEMDRO96>
  <OEMLED96>0</OEMLED96>
  <OEMDRO97>0.</OEMDRO97>
  <OEMLED97>0</OEMLED97>
  <OEMDRO98>0.</OEMDRO98>
  <OEMLED98>0</OEMLED98>
  <OEMDRO99>0.</OEMDRO99>
  <OEMLED99>0</OEMLED99>
  <OEMDRO100>0.</OEMDRO100>
  <OEMLED100>0</OEMLED100>
  <OEMDRO101>0.</OEMDRO101>
  <OEMLED101>0</OEMLED101>
  <OEMDRO102>0.</OEMDRO102>
  <OEMLED102>0</OEMLED102>
  <OEMDRO103>0.</OEMDRO103>
  <OEMLED103>0</OEMLED103>
  <OEMDRO104>0.</OEMDRO104>
  <OEMLED104>0</OEMLED104>
  <OEMDRO105>0.</OEMDRO105>
  <OEMLED105>0</OEMLED105>
  <OEMDRO106>0.</OEMDRO106>
  <OEMLED106>0</OEMLED106>
  <OEMDRO107>0.</OEMDRO107>
  <OEMLED107>0</OEMLED107>
  <OEMDRO108>0.</OEMDRO108>
  <OEMLED108>0</OEMLED108>
  <OEMDRO109>0.</OEMDRO109>
  <OEMLED109>0</OEMLED109>
  <OEMDRO110>0.</OEMDRO110>
  <OEMLED110>0</OEMLED110>
  <OEMDRO111>0.</OEMDRO111>
  <OEMLED111>0</OEMLED111>
  <OEMDRO112>0.</OEMDRO112>
  <OEMLED112>0</OEMLED112>
  <OEMDRO113>0.</OEMDRO113>
  <OEMLED113>0</OEMLED113>
  <OEMDRO114>0.</OEMDRO114>
  <OEMLED114>0</OEMLED114>
  <OEMDRO115>0.</OEMDRO115>
  <OEMLED115>0</OEMLED115>
  <OEMDRO116>0.</OEMDRO116>
  <OEMLED116>0</OEMLED116>
  <OEMDRO117>0.</OEMDRO117>
  <OEMLED117>0</OEMLED117>
  <OEMDRO118>0.</OEMDRO118>
  <OEMLED118>0</OEMLED118>
  <OEMDRO119>0.</OEMDRO119>
  <OEMLED119>0</OEMLED119>
  <OEMDRO120>0.</OEMDRO120>
  <OEMLED120>0</OEMLED120>
  <OEMDRO121>0.</OEMDRO121>
  <OEMLED121>0</OEMLED121>
  <OEMDRO122>0.</OEMDRO122>
  <OEMLED122>0</OEMLED122>
  <OEMDRO123>0.</OEMDRO123>
  <OEMLED123>0</OEMLED123>
  <OEMDRO124>0.</OEMDRO124>
  <OEMLED124>0</OEMLED124>
  <OEMDRO125>0.</OEMDRO125>
  <OEMLED125>0</OEMLED125>
  <OEMDRO126>0.</OEMDRO126>
  <OEMLED126>0</OEMLED126>
  <OEMDRO127>0.</OEMDRO127>
  <OEMLED127>0</OEMLED127>
  <OEMDRO128>0.</OEMDRO128>
  <OEMLED128>0</OEMLED128>
  <OEMDRO129>0.</OEMDRO129>
  <OEMLED129>0</OEMLED129>
  <OEMDRO130>0.</OEMDRO130>
  <OEMLED130>0</OEMLED130>
  <OEMDRO131>0.</OEMDRO131>
  <OEMLED131>0</OEMLED131>
  <OEMDRO132>0.</OEMDRO132>
  <OEMLED132>0</OEMLED132>
  <OEMDRO133>0.</OEMDRO133>
  <OEMLED133>0</OEMLED133>
  <OEMDRO134>0.</OEMDRO134>
  <OEMLED134>0</OEMLED134>
  <OEMDRO135>0.</OEMDRO135>
  <OEMLED135>0</OEMLED135>
  <OEMDRO136>0.</OEMDRO136>
  <OEMLED136>0</OEMLED136>
  <OEMDRO137>0.</OEMDRO137>
  <OEMLED137>0</OEMLED137>
  <OEMDRO138>0.</OEMDRO138>
  <OEMLED138>0</OEMLED138>
  <OEMDRO139>0.</OEMDRO139>
  <OEMLED139>0</OEMLED139>
  <OEMDRO140>0.</OEMDRO140>
  <OEMLED140>0</OEMLED140>
  <OEMDRO141>0.</OEMDRO141>
  <OEMLED141>0</OEMLED141>
  <OEMDRO142>0.</OEMDRO142>
  <OEMLED142>0</OEMLED142>
  <OEMDRO143>0.</OEMDRO143>
  <OEMLED143>0</OEMLED143>
  <OEMDRO144>0.</OEMDRO144>
  <OEMLED144>0</OEMLED144>
  <OEMDRO145>0.</OEMDRO145>
  <OEMLED145>0</OEMLED145>
  <OEMDRO146>0.</OEMDRO146>
  <OEMLED146>0</OEMLED146>
  <OEMDRO147>0.</OEMDRO147>
  <OEMLED147>0</OEMLED147>
  <OEMDRO148>0.</OEMDRO148>
  <OEMLED148>0</OEMLED148>
  <OEMDRO149>0.</OEMDRO149>
  <OEMLED149>0</OEMLED149>
  <OEMDRO150>0.</OEMDRO150>
  <OEMLED150>0</OEMLED150>
  <OEMDRO151>0.</OEMDRO151>
  <OEMLED151>0</OEMLED151>
  <OEMDRO152>0.</OEMDRO152>
  <OEMLED152>0</OEMLED152>
  <OEMDRO153>0.</OEMDRO153>
  <OEMLED153>0</OEMLED153>
  <OEMDRO154>0.</OEMDRO154>
  <OEMLED154>0</OEMLED154>
  <OEMDRO155>0.</OEMDRO155>
  <OEMLED155>0</OEMLED155>
  <OEMDRO156>0.</OEMDRO156>
  <OEMLED156>0</OEMLED156>
  <OEMDRO157>0.</OEMDRO157>
  <OEMLED157>0</OEMLED157>
  <OEMDRO158>0.</OEMDRO158>
  <OEMLED158>0</OEMLED158>
  <OEMDRO159>0.</OEMDRO159>
  <OEMLED159>0</OEMLED159>
  <OEMDRO160>0.</OEMDRO160>
  <OEMLED160>0</OEMLED160>
  <OEMDRO161>0.</OEMDRO161>
  <OEMLED161>0</OEMLED161>
  <OEMDRO162>0.</OEMDRO162>
  <OEMLED162>0</OEMLED162>
  <OEMDRO163>0.</OEMDRO163>
  <OEMLED163>0</OEMLED163>
  <OEMDRO164>0.</OEMDRO164>
  <OEMLED164>0</OEMLED164>
  <OEMDRO165>0.</OEMDRO165>
  <OEMLED165>0</OEMLED165>
  <OEMDRO166>0.</OEMDRO166>
  <OEMLED166>0</OEMLED166>
  <OEMDRO167>0.</OEMDRO167>
  <OEMLED167>0</OEMLED167>
  <OEMDRO168>0.</OEMDRO168>
  <OEMLED168>0</OEMLED168>
  <OEMDRO169>0.</OEMDRO169>
  <OEMLED169>0</OEMLED169>
  <OEMDRO170>0.</OEMDRO170>
  <OEMLED170>0</OEMLED170>
  <OEMDRO171>0.</OEMDRO171>
  <OEMLED171>0</OEMLED171>
  <OEMDRO172>0.</OEMDRO172>
  <OEMLED172>0</OEMLED172>
  <OEMDRO173>0.</OEMDRO173>
  <OEMLED173>0</OEMLED173>
  <OEMDRO174>0.</OEMDRO174>
  <OEMLED174>0</OEMLED174>
  <OEMDRO175>0.</OEMDRO175>
  <OEMLED175>0</OEMLED175>
  <OEMDRO176>0.</OEMDRO176>
  <OEMLED176>0</OEMLED176>
  <OEMDRO177>0.</OEMDRO177>
  <OEMLED177>0</OEMLED177>
  <OEMDRO178>0.</OEMDRO178>
  <OEMLED178>0</OEMLED178>
  <OEMDRO179>0.</OEMDRO179>
  <OEMLED179>0</OEMLED179>
  <OEMDRO180>0.</OEMDRO180>
  <OEMLED180>0</OEMLED180>
  <OEMDRO181>0.</OEMDRO181>
  <OEMLED181>0</OEMLED181>
  <OEMDRO182>0.</OEMDRO182>
  <OEMLED182>0</OEMLED182>
  <OEMDRO183>0.</OEMDRO183>
  <OEMLED183>0</OEMLED183>
  <OEMDRO184>0.</OEMDRO184>
  <OEMLED184>0</OEMLED184>
  <OEMDRO185>0.</OEMDRO185>
  <OEMLED185>0</OEMLED185>
  <OEMDRO186>0.</OEMDRO186>
  <OEMLED186>0</OEMLED186>
  <OEMDRO187>0.</OEMDRO187>
  <OEMLED187>0</OEMLED187>
  <OEMDRO188>0.</OEMDRO188>
  <OEMLED188>0</OEMLED188>
  <OEMDRO189>0.</OEMDRO189>
  <OEMLED189>0</OEMLED189>
  <OEMDRO190>0.</OEMDRO190>
  <OEMLED190>0</OEMLED190>
  <OEMDRO191>0.</OEMDRO191>
  <OEMLED191>0</OEMLED191>
  <OEMDRO192>0.</OEMDRO192>
  <OEMLED192>0</OEMLED192>
  <OEMDRO193>0.</OEMDRO193>
  <OEMLED193>0</OEMLED193>
  <OEMDRO194>0.</OEMDRO194>
  <OEMLED194>0</OEMLED194>
  <OEMDRO195>0.</OEMDRO195>
  <OEMLED195>0</OEMLED195>
  <OEMDRO196>0.</OEMDRO196>
  <OEMLED196>0</OEMLED196>
  <OEMDRO197>0.</OEMDRO197>
  <OEMLED197>0</OEMLED197>
  <OEMDRO198>0.</OEMDRO198>
  <OEMLED198>0</OEMLED198>
  <OEMDRO199>0.</OEMDRO199>
  <OEMLED199>0</OEMLED199>
  <OEMDRO200>0.</OEMDRO200>
  <OEMLED200>0</OEMLED200>
  <OEMDRO201>0.</OEMDRO201>
  <OEMLED201>0</OEMLED201>
  <OEMDRO202>0.</OEMDRO202>
  <OEMLED202>0</OEMLED202>
  <OEMDRO203>0.</OEMDRO203>
  <OEMLED203>0</OEMLED203>
  <OEMDRO204>0.</OEMDRO204>
  <OEMLED204>0</OEMLED204>
  <OEMDRO205>0.</OEMDRO205>
  <OEMLED205>0</OEMLED205>
  <OEMDRO206>0.</OEMDRO206>
  <OEMLED206>0</OEMLED206>
  <OEMDRO207>0.</OEMDRO207>
  <OEMLED207>0</OEMLED207>
  <OEMDRO208>0.</OEMDRO208>
  <OEMLED208>0</OEMLED208>
  <OEMDRO209>0.</OEMDRO209>
  <OEMLED209>0</OEMLED209>
  <OEMDRO210>0.</OEMDRO210>
  <OEMLED210>0</OEMLED210>
  <OEMDRO211>0.</OEMDRO211>
  <OEMLED211>0</OEMLED211>
  <OEMDRO212>0.</OEMDRO212>
  <OEMLED212>0</OEMLED212>
  <OEMDRO213>0.</OEMDRO213>
  <OEMLED213>0</OEMLED213>
  <OEMDRO214>0.</OEMDRO214>
  <OEMLED214>0</OEMLED214>
  <OEMDRO215>0.</OEMDRO215>
  <OEMLED215>0</OEMLED215>
  <OEMDRO216>0.</OEMDRO216>
  <OEMLED216>0</OEMLED216>
  <OEMDRO217>0.</OEMDRO217>
  <OEMLED217>0</OEMLED217>
  <OEMDRO218>0.</OEMDRO218>
  <OEMLED218>0</OEMLED218>
  <OEMDRO219>0.</OEMDRO219>
  <OEMLED219>0</OEMLED219>
  <OEMDRO220>0.</OEMDRO220>
  <OEMLED220>0</OEMLED220>
  <OEMDRO221>0.</OEMDRO221>
  <OEMLED221>0</OEMLED221>
  <OEMDRO222>0.</OEMDRO222>
  <OEMLED222>0</OEMLED222>
  <OEMDRO223>0.</OEMDRO223>
  <OEMLED223>0</OEMLED223>
  <OEMDRO224>0.</OEMDRO224>
  <OEMLED224>0</OEMLED224>
  <OEMDRO225>0.</OEMDRO225>
  <OEMLED225>0</OEMLED225>
  <OEMDRO226>0.</OEMDRO226>
  <OEMLED226>0</OEMLED226>
  <OEMDRO227>0.</OEMDRO227>
  <OEMLED227>0</OEMLED227>
  <OEMDRO228>0.</OEMDRO228>
  <OEMLED228>0</OEMLED228>
  <OEMDRO229>0.</OEMDRO229>
  <OEMLED229>0</OEMLED229>
  <OEMDRO230>0.</OEMDRO230>
  <OEMLED230>0</OEMLED230>
  <OEMDRO231>0.</OEMDRO231>
  <OEMLED231>0</OEMLED231>
  <OEMDRO232>0.</OEMDRO232>
  <OEMLED232>0</OEMLED232>
  <OEMDRO233>0.</OEMDRO233>
  <OEMLED233>0</OEMLED233>
  <OEMDRO234>0.</OEMDRO234>
  <OEMLED234>0</OEMLED234>
  <OEMDRO235>0.</OEMDRO235>
  <OEMLED235>0</OEMLED235>
  <OEMDRO236>0.</OEMDRO236>
  <OEMLED236>0</OEMLED236>
  <OEMDRO237>0.</OEMDRO237>
  <OEMLED237>0</OEMLED237>
  <OEMDRO238>0.</OEMDRO238>
  <OEMLED238>0</OEMLED238>
  <OEMDRO239>0.</OEMDRO239>
  <OEMLED239>0</OEMLED239>
  <OEMDRO240>0.</OEMDRO240>
  <OEMLED240>0</OEMLED240>
  <OEMDRO241>0.</OEMDRO241>
  <OEMLED241>0</OEMLED241>
  <OEMDRO242>0.</OEMDRO242>
  <OEMLED242>0</OEMLED242>
  <OEMDRO243>0.</OEMDRO243>
  <OEMLED243>0</OEMLED243>
  <OEMDRO244>0.</OEMDRO244>
  <OEMLED244>0</OEMLED244>
  <OEMDRO245>0.</OEMDRO245>
  <OEMLED245>0</OEMLED245>
  <OEMDRO246>0.</OEMDRO246>
  <OEMLED246>0</OEMLED246>
  <OEMDRO247>0.</OEMDRO247>
  <OEMLED247>0</OEMLED247>
  <OEMDRO248>0.</OEMDRO248>
  <OEMLED248>0</OEMLED248>
  <OEMDRO249>0.</OEMDRO249>
  <OEMLED249>0</OEMLED249>
  <OEMDRO250>0.</OEMDRO250>
  <OEMLED250>0</OEMLED250>
  <OEMDRO251>0.</OEMDRO251>
  <OEMLED251>0</OEMLED251>
  <OEMDRO252>0.</OEMDRO252>
  <OEMLED252>0</OEMLED252>
  <OEMDRO253>0.</OEMDRO253>
  <OEMLED253>0</OEMLED253>
  <OEMDRO254>0.</OEMDRO254>
  <OEMLED254>0</OEMLED254>
  <OEMDRO255>0.</OEMDRO255>
  <OEMLED255>0</OEMLED255>
  <JogInc>1.</JogInc>
  <JogSlide>0.1</JogSlide>
  <THCMax>1.</THCMax>
  <THCMin>0.2</THCMin>
  <RadiusA>0.</RadiusA>
  <RadiusB>0.</RadiusB>
  <RadiusC>0.</RadiusC>
  <LiftLevel>1.</LiftLevel>
  <LiftAngle>45.</LiftAngle>
  <InhibitDepth>0.</InhibitDepth>
  <LaserXGrid>0.</LaserXGrid>
  <LaserYGrid>0.</LaserYGrid>
  <LaserAGrid>0.</LaserAGrid>
  <JogInc0>1.</JogInc0>
  <JogInc1>0.1</JogInc1>
  <JogInc2>1.e-002</JogInc2>
  <JogInc3>1.e-003</JogInc3>
  <JogInc4>1.e-004</JogInc4>
  <JogInc5>1.</JogInc5>
  <JogInc6>0.1</JogInc6>
Re: nidet help
« Reply #8 on: May 07, 2011, 06:59:40 AM »
  <JogInc7>1.e-002</JogInc7>
  <JogInc8>1.e-003</JogInc8>
  <JogInc9>1.e-004</JogInc9>
  <THCSpeed>20.</THCSpeed>
  <BlendFactor>180.</BlendFactor>
  <M0RefHome>0</M0RefHome>
  <M1RefHome>0</M1RefHome>
  <M2RefHome>0</M2RefHome>
  <M3RefHome>0</M3RefHome>
  <M4RefHome>0</M4RefHome>
  <M5RefHome>0</M5RefHome>
  <Running>0</Running>
  <Encoder0>0</Encoder0>
  <Encoder1>0</Encoder1>
  <Encoder2>0</Encoder2>
  <Encoder3>0</Encoder3>
  <Encoder4>0</Encoder4>
  <Encoder5>0</Encoder5>
  <Encoder6>0</Encoder6>
  <Syskey1>1</Syskey1>
  <DefDir>C:\Mach3</DefDir>
  <Profile>540B nowe</Profile>
  <NewPath>0</NewPath>
  <BR>0.</BR>
  <BG>0.</BG>
  <BB>0.</BB>
  <FR>0.</FR>
  <FG>0.</FG>
  <FB>1.</FB>
  <RR>1.</RR>
  <RG>0.</RG>
  <RB>0.</RB>
  <AR>0.7</AR>
  <AG>0.2</AG>
  <AB>0.7</AB>
  <ER>1.</ER>
  <EG>1.</EG>
  <EB>0.</EB>
  <ID>None</ID>
  <FirstRun>1</FirstRun>
  <LastUser>DT Clining Service</LastUser>
  <PulseSpeed>0</PulseSpeed>
  <Layout>6Axis.set</Layout>
  <Serial>0</Serial>
  <SerialServo>0</SerialServo>
  <Port2Input>0</Port2Input>
  <GeckoMode>0</GeckoMode>
  <USBINPUTS>16</USBINPUTS>
  <USBOUTPUTS>16</USBOUTPUTS>
  <Port2On>0</Port2On>
  <Port1On>1</Port1On>
  <Port1Add>888</Port1Add>
  <Port2Add>632</Port2Add>
  <MaxCL>0</MaxCL>
  <ModPlug>0</ModPlug>
  <TCPMODBUS>0</TCPMODBUS>
  <Configured>1</Configured>
  <Units>0</Units>
  <Motor0Active>1</Motor0Active>
  <Motor0DirNeg>0</Motor0DirNeg>
  <Motor0DirPort>1</Motor0DirPort>
  <Motor0DirPin>3</Motor0DirPin>
  <Motor0StepNeg>1</Motor0StepNeg>
  <Motor0StepPort>1</Motor0StepPort>
  <Motor0StepPin>2</Motor0StepPin>
  <Motor1Active>1</Motor1Active>
  <Motor1DirNeg>1</Motor1DirNeg>
  <Motor1DirPort>1</Motor1DirPort>
  <Motor1DirPin>5</Motor1DirPin>
  <Motor1StepNeg>0</Motor1StepNeg>
  <Motor1StepPort>1</Motor1StepPort>
  <Motor1StepPin>4</Motor1StepPin>
  <Motor2Active>1</Motor2Active>
  <Motor2DirNeg>0</Motor2DirNeg>
  <Motor2DirPort>1</Motor2DirPort>
  <Motor2DirPin>7</Motor2DirPin>
  <Motor2StepNeg>1</Motor2StepNeg>
  <Motor2StepPort>1</Motor2StepPort>
  <Motor2StepPin>6</Motor2StepPin>
  <Motor3Active>1</Motor3Active>
  <Motor3DirNeg>0</Motor3DirNeg>
  <Motor3DirPort>1</Motor3DirPort>
  <Motor3DirPin>9</Motor3DirPin>
  <Motor3StepNeg>0</Motor3StepNeg>
  <Motor3StepPort>1</Motor3StepPort>
  <Motor3StepPin>8</Motor3StepPin>
  <Motor4Active>0</Motor4Active>
  <Motor4DirNeg>0</Motor4DirNeg>
  <Motor4DirPort>0</Motor4DirPort>
  <Motor4DirPin>0</Motor4DirPin>
  <Motor4StepNeg>0</Motor4StepNeg>
  <Motor4StepPort>0</Motor4StepPort>
  <Motor4StepPin>0</Motor4StepPin>
  <Motor5Active>0</Motor5Active>
  <Motor5DirNeg>0</Motor5DirNeg>
  <Motor5DirPort>0</Motor5DirPort>
  <Motor5DirPin>0</Motor5DirPin>
  <Motor5StepNeg>0</Motor5StepNeg>
  <Motor5StepPort>0</Motor5StepPort>
  <Motor5StepPin>0</Motor5StepPin>
  <Motor6Active>0</Motor6Active>
  <Motor6DirNeg>0</Motor6DirNeg>
  <Motor6DirPort>0</Motor6DirPort>
  <Motor6DirPin>0</Motor6DirPin>
  <Motor6StepNeg>0</Motor6StepNeg>
  <Motor6StepPort>0</Motor6StepPort>
  <Motor6StepPin>0</Motor6StepPin>
  <Input0Active>0</Input0Active>
  <Input0Port>0</Input0Port>
  <Input0Pin>0</Input0Pin>
  <Input0Neg>0</Input0Neg>
  <Input0Emulated>0</Input0Emulated>
  <Input0EmuKey>0</Input0EmuKey>
  <Input1Active>0</Input1Active>
  <Input1Port>0</Input1Port>
  <Input1Pin>0</Input1Pin>
  <Input1Neg>0</Input1Neg>
  <Input1Emulated>0</Input1Emulated>
  <Input1EmuKey>0</Input1EmuKey>
  <Input2Active>0</Input2Active>
  <Input2Port>0</Input2Port>
  <Input2Pin>0</Input2Pin>
  <Input2Neg>0</Input2Neg>
  <Input2Emulated>0</Input2Emulated>
  <Input2EmuKey>0</Input2EmuKey>
  <Input3Active>0</Input3Active>
  <Input3Port>0</Input3Port>
  <Input3Pin>0</Input3Pin>
  <Input3Neg>0</Input3Neg>
  <Input3Emulated>0</Input3Emulated>
  <Input3EmuKey>0</Input3EmuKey>
  <Input4Active>0</Input4Active>
  <Input4Port>0</Input4Port>
  <Input4Pin>0</Input4Pin>
  <Input4Neg>0</Input4Neg>
  <Input4Emulated>0</Input4Emulated>
  <Input4EmuKey>0</Input4EmuKey>
  <Input5Active>0</Input5Active>
  <Input5Port>0</Input5Port>
  <Input5Pin>0</Input5Pin>
  <Input5Neg>0</Input5Neg>
  <Input5Emulated>0</Input5Emulated>
  <Input5EmuKey>0</Input5EmuKey>
  <Input6Active>0</Input6Active>
  <Input6Port>0</Input6Port>
  <Input6Pin>0</Input6Pin>
  <Input6Neg>0</Input6Neg>
  <Input6Emulated>0</Input6Emulated>
  <Input6EmuKey>0</Input6EmuKey>
  <Input7Active>0</Input7Active>
  <Input7Port>0</Input7Port>
  <Input7Pin>0</Input7Pin>
  <Input7Neg>0</Input7Neg>
  <Input7Emulated>0</Input7Emulated>
  <Input7EmuKey>0</Input7EmuKey>
  <Input8Active>0</Input8Active>
  <Input8Port>0</Input8Port>
  <Input8Pin>0</Input8Pin>
  <Input8Neg>0</Input8Neg>
  <Input8Emulated>0</Input8Emulated>
  <Input8EmuKey>0</Input8EmuKey>
  <Input9Active>0</Input9Active>
  <Input9Port>0</Input9Port>
  <Input9Pin>0</Input9Pin>
  <Input9Neg>0</Input9Neg>
  <Input9Emulated>0</Input9Emulated>
  <Input9EmuKey>0</Input9EmuKey>
  <Input10Active>0</Input10Active>
  <Input10Port>0</Input10Port>
  <Input10Pin>0</Input10Pin>
  <Input10Neg>0</Input10Neg>
  <Input10Emulated>0</Input10Emulated>
  <Input10EmuKey>0</Input10EmuKey>
  <Input11Active>0</Input11Active>
  <Input11Port>0</Input11Port>
  <Input11Pin>0</Input11Pin>
  <Input11Neg>0</Input11Neg>
  <Input11Emulated>0</Input11Emulated>
  <Input11EmuKey>0</Input11EmuKey>
  <Input12Active>0</Input12Active>
  <Input12Port>0</Input12Port>
  <Input12Pin>0</Input12Pin>
  <Input12Neg>0</Input12Neg>
  <Input12Emulated>0</Input12Emulated>
  <Input12EmuKey>0</Input12EmuKey>
  <Input13Active>0</Input13Active>
  <Input13Port>0</Input13Port>
  <Input13Pin>0</Input13Pin>
  <Input13Neg>0</Input13Neg>
  <Input13Emulated>0</Input13Emulated>
  <Input13EmuKey>0</Input13EmuKey>
  <Input14Active>0</Input14Active>
  <Input14Port>0</Input14Port>
  <Input14Pin>0</Input14Pin>
  <Input14Neg>0</Input14Neg>
  <Input14Emulated>0</Input14Emulated>
  <Input14EmuKey>0</Input14EmuKey>
  <Input15Active>0</Input15Active>
  <Input15Port>0</Input15Port>
  <Input15Pin>0</Input15Pin>
  <Input15Neg>0</Input15Neg>
  <Input15Emulated>0</Input15Emulated>
  <Input15EmuKey>0</Input15EmuKey>
  <Input16Active>0</Input16Active>
  <Input16Port>0</Input16Port>
  <Input16Pin>0</Input16Pin>
  <Input16Neg>0</Input16Neg>
  <Input16Emulated>0</Input16Emulated>
  <Input16EmuKey>0</Input16EmuKey>
  <Input17Active>0</Input17Active>
  <Input17Port>0</Input17Port>
  <Input17Pin>0</Input17Pin>
  <Input17Neg>0</Input17Neg>
  <Input17Emulated>0</Input17Emulated>
  <Input17EmuKey>0</Input17EmuKey>
  <Input18Active>0</Input18Active>
  <Input18Port>0</Input18Port>
  <Input18Pin>0</Input18Pin>
  <Input18Neg>0</Input18Neg>
  <Input18Emulated>0</Input18Emulated>
  <Input18EmuKey>0</Input18EmuKey>
  <Input19Active>0</Input19Active>
  <Input19Port>0</Input19Port>
  <Input19Pin>0</Input19Pin>
  <Input19Neg>0</Input19Neg>
  <Input19Emulated>0</Input19Emulated>
  <Input19EmuKey>0</Input19EmuKey>
  <Input20Active>0</Input20Active>
  <Input20Port>0</Input20Port>
  <Input20Pin>0</Input20Pin>
  <Input20Neg>0</Input20Neg>
  <Input20Emulated>0</Input20Emulated>
  <Input20EmuKey>0</Input20EmuKey>
  <Input21Active>0</Input21Active>
  <Input21Port>0</Input21Port>
  <Input21Pin>0</Input21Pin>
  <Input21Neg>0</Input21Neg>
  <Input21Emulated>0</Input21Emulated>
  <Input21EmuKey>0</Input21EmuKey>
  <Input22Active>0</Input22Active>
  <Input22Port>0</Input22Port>
  <Input22Pin>0</Input22Pin>
  <Input22Neg>0</Input22Neg>
  <Input22Emulated>0</Input22Emulated>
  <Input22EmuKey>0</Input22EmuKey>
  <Input23Active>0</Input23Active>
  <Input23Port>0</Input23Port>
  <Input23Pin>0</Input23Pin>
  <Input23Neg>0</Input23Neg>
  <Input23Emulated>0</Input23Emulated>
  <Input23EmuKey>0</Input23EmuKey>
  <Input24Active>0</Input24Active>
  <Input24Port>0</Input24Port>
  <Input24Pin>0</Input24Pin>
  <Input24Neg>0</Input24Neg>
  <Input24Emulated>0</Input24Emulated>
  <Input24EmuKey>0</Input24EmuKey>
  <Input25Active>1</Input25Active>
  <Input25Port>1</Input25Port>
  <Input25Pin>0</Input25Pin>
  <Input25Neg>0</Input25Neg>
  <Input25Emulated>0</Input25Emulated>
  <Input25EmuKey>0</Input25EmuKey>
  <Input26Active>0</Input26Active>
  <Input26Port>0</Input26Port>
  <Input26Pin>0</Input26Pin>
  <Input26Neg>0</Input26Neg>
  <Input26Emulated>0</Input26Emulated>
  <Input26EmuKey>0</Input26EmuKey>
  <Input27Active>0</Input27Active>
  <Input27Port>0</Input27Port>
  <Input27Pin>0</Input27Pin>
  <Input27Neg>0</Input27Neg>
  <Input27Emulated>0</Input27Emulated>
  <Input27EmuKey>0</Input27EmuKey>
  <Input28Active>0</Input28Active>
  <Input28Port>0</Input28Port>
  <Input28Pin>0</Input28Pin>
  <Input28Neg>0</Input28Neg>
  <Input28Emulated>0</Input28Emulated>
  <Input28EmuKey>0</Input28EmuKey>
  <Input29Active>0</Input29Active>
  <Input29Port>0</Input29Port>
  <Input29Pin>0</Input29Pin>
  <Input29Neg>0</Input29Neg>
  <Input29Emulated>0</Input29Emulated>
  <Input29EmuKey>0</Input29EmuKey>
  <Input30Active>0</Input30Active>
  <Input30Port>0</Input30Port>
  <Input30Pin>0</Input30Pin>
  <Input30Neg>0</Input30Neg>
  <Input30Emulated>0</Input30Emulated>
  <Input30EmuKey>0</Input30EmuKey>
  <Input31Active>0</Input31Active>
  <Input31Port>0</Input31Port>
  <Input31Pin>0</Input31Pin>
  <Input31Neg>0</Input31Neg>
  <Input31Emulated>0</Input31Emulated>
  <Input31EmuKey>0</Input31EmuKey>
  <Input32Active>0</Input32Active>
  <Input32Port>0</Input32Port>
  <Input32Pin>0</Input32Pin>
  <Input32Neg>0</Input32Neg>
  <Input32Emulated>0</Input32Emulated>
  <Input32EmuKey>0</Input32EmuKey>
  <Input33Active>0</Input33Active>
  <Input33Port>0</Input33Port>
  <Input33Pin>0</Input33Pin>
  <Input33Neg>0</Input33Neg>
  <Input33Emulated>0</Input33Emulated>
  <Input33EmuKey>0</Input33EmuKey>
  <Input34Active>0</Input34Active>
  <Input34Port>0</Input34Port>
  <Input34Pin>0</Input34Pin>
  <Input34Neg>0</Input34Neg>
  <Input34Emulated>0</Input34Emulated>
  <Input34EmuKey>0</Input34EmuKey>
  <Input35Active>0</Input35Active>
  <Input35Port>0</Input35Port>
  <Input35Pin>0</Input35Pin>
  <Input35Neg>0</Input35Neg>
  <Input35Emulated>0</Input35Emulated>
  <Input35EmuKey>0</Input35EmuKey>
  <Input36Active>0</Input36Active>
  <Input36Port>0</Input36Port>
  <Input36Pin>0</Input36Pin>
  <Input36Neg>0</Input36Neg>
  <Input36Emulated>0</Input36Emulated>
  <Input36EmuKey>0</Input36EmuKey>
  <Input37Active>0</Input37Active>
  <Input37Port>0</Input37Port>
  <Input37Pin>0</Input37Pin>
  <Input37Neg>0</Input37Neg>
  <Input37Emulated>0</Input37Emulated>
  <Input37EmuKey>0</Input37EmuKey>
  <Input38Active>0</Input38Active>
  <Input38Port>0</Input38Port>
  <Input38Pin>0</Input38Pin>
  <Input38Neg>0</Input38Neg>
  <Input38Emulated>0</Input38Emulated>
  <Input38EmuKey>0</Input38EmuKey>
  <Input39Active>0</Input39Active>
  <Input39Port>0</Input39Port>
  <Input39Pin>0</Input39Pin>
  <Input39Neg>0</Input39Neg>
  <Input39Emulated>0</Input39Emulated>
  <Input39EmuKey>0</Input39EmuKey>
  <Input40Active>0</Input40Active>
  <Input40Port>0</Input40Port>
  <Input40Pin>0</Input40Pin>
  <Input40Neg>0</Input40Neg>
  <Input40Emulated>0</Input40Emulated>
  <Input40EmuKey>0</Input40EmuKey>
  <Input41Active>0</Input41Active>
  <Input41Port>0</Input41Port>
  <Input41Pin>0</Input41Pin>
  <Input41Neg>0</Input41Neg>
  <Input41Emulated>0</Input41Emulated>
  <Input41EmuKey>0</Input41EmuKey>
  <Input42Active>0</Input42Active>
  <Input42Port>0</Input42Port>
  <Input42Pin>0</Input42Pin>
  <Input42Neg>0</Input42Neg>
  <Input42Emulated>0</Input42Emulated>
  <Input42EmuKey>0</Input42EmuKey>
  <Input43Active>0</Input43Active>
  <Input43Port>0</Input43Port>
  <Input43Pin>0</Input43Pin>
  <Input43Neg>0</Input43Neg>
  <Input43Emulated>0</Input43Emulated>
  <Input43EmuKey>0</Input43EmuKey>
  <Input44Active>0</Input44Active>
  <Input44Port>0</Input44Port>
  <Input44Pin>0</Input44Pin>
  <Input44Neg>0</Input44Neg>
  <Input44Emulated>0</Input44Emulated>
  <Input44EmuKey>0</Input44EmuKey>
  <Input45Active>0</Input45Active>
  <Input45Port>0</Input45Port>
  <Input45Pin>0</Input45Pin>
  <Input45Neg>0</Input45Neg>
  <Input45Emulated>0</Input45Emulated>
  <Input45EmuKey>0</Input45EmuKey>
  <Input46Active>0</Input46Active>
Re: nidet help
« Reply #9 on: May 07, 2011, 07:00:03 AM »
<Input46Port>0</Input46Port>
  <Input46Pin>0</Input46Pin>
  <Input46Neg>0</Input46Neg>
  <Input46Emulated>0</Input46Emulated>
  <Input46EmuKey>0</Input46EmuKey>
  <Input47Active>0</Input47Active>
  <Input47Port>0</Input47Port>
  <Input47Pin>0</Input47Pin>
  <Input47Neg>0</Input47Neg>
  <Input47Emulated>0</Input47Emulated>
  <Input47EmuKey>0</Input47EmuKey>
  <Input48Active>0</Input48Active>
  <Input48Port>0</Input48Port>
  <Input48Pin>0</Input48Pin>
  <Input48Neg>0</Input48Neg>
  <Input48Emulated>0</Input48Emulated>
  <Input48EmuKey>0</Input48EmuKey>
  <Input49Active>0</Input49Active>
  <Input49Port>0</Input49Port>
  <Input49Pin>0</Input49Pin>
  <Input49Neg>0</Input49Neg>
  <Input49Emulated>0</Input49Emulated>
  <Input49EmuKey>0</Input49EmuKey>
  <Input50Active>0</Input50Active>
  <Input50Port>0</Input50Port>
  <Input50Pin>0</Input50Pin>
  <Input50Neg>0</Input50Neg>
  <Input50Emulated>0</Input50Emulated>
  <Input50EmuKey>0</Input50EmuKey>
  <Input51Active>0</Input51Active>
  <Input51Port>0</Input51Port>
  <Input51Pin>0</Input51Pin>
  <Input51Neg>0</Input51Neg>
  <Input51Emulated>0</Input51Emulated>
  <Input51EmuKey>0</Input51EmuKey>
  <Input52Active>0</Input52Active>
  <Input52Port>0</Input52Port>
  <Input52Pin>0</Input52Pin>
  <Input52Neg>0</Input52Neg>
  <Input52Emulated>0</Input52Emulated>
  <Input52EmuKey>0</Input52EmuKey>
  <Output0Active>0</Output0Active>
  <Output0Port>0</Output0Port>
  <Output0Pin>0</Output0Pin>
  <Output0Neg>0</Output0Neg>
  <Output1Active>0</Output1Active>
  <Output1Port>0</Output1Port>
  <Output1Pin>0</Output1Pin>
  <Output1Neg>0</Output1Neg>
  <Output2Active>0</Output2Active>
  <Output2Port>0</Output2Port>
  <Output2Pin>0</Output2Pin>
  <Output2Neg>0</Output2Neg>
  <Output3Active>0</Output3Active>
  <Output3Port>0</Output3Port>
  <Output3Pin>0</Output3Pin>
  <Output3Neg>0</Output3Neg>
  <Output4Active>0</Output4Active>
  <Output4Port>0</Output4Port>
  <Output4Pin>0</Output4Pin>
  <Output4Neg>0</Output4Neg>
  <Output5Active>0</Output5Active>
  <Output5Port>0</Output5Port>
  <Output5Pin>0</Output5Pin>
  <Output5Neg>0</Output5Neg>
  <Output6Active>0</Output6Active>
  <Output6Port>0</Output6Port>
  <Output6Pin>0</Output6Pin>
  <Output6Neg>0</Output6Neg>
  <Output7Active>1</Output7Active>
  <Output7Port>1</Output7Port>
  <Output7Pin>17</Output7Pin>
  <Output7Neg>0</Output7Neg>
  <Output8Active>0</Output8Active>
  <Output8Port>0</Output8Port>
  <Output8Pin>0</Output8Pin>
  <Output8Neg>0</Output8Neg>
  <Output9Active>0</Output9Active>
  <Output9Port>0</Output9Port>
  <Output9Pin>0</Output9Pin>
  <Output9Neg>0</Output9Neg>
  <Output10Active>0</Output10Active>
  <Output10Port>0</Output10Port>
  <Output10Pin>0</Output10Pin>
  <Output10Neg>0</Output10Neg>
  <Output11Active>0</Output11Active>
  <Output11Port>0</Output11Port>
  <Output11Pin>0</Output11Pin>
  <Output11Neg>0</Output11Neg>
  <Output12Active>0</Output12Active>
  <Output12Port>0</Output12Port>
  <Output12Pin>0</Output12Pin>
  <Output12Neg>0</Output12Neg>
  <Output13Active>1</Output13Active>
  <Output13Port>1</Output13Port>
  <Output13Pin>16</Output13Pin>
  <Output13Neg>0</Output13Neg>
  <Output14Active>0</Output14Active>
  <Output14Port>0</Output14Port>
  <Output14Pin>0</Output14Pin>
  <Output14Neg>0</Output14Neg>
  <Output15Active>0</Output15Active>
  <Output15Port>0</Output15Port>
  <Output15Pin>0</Output15Pin>
  <Output15Neg>0</Output15Neg>
  <Output16Active>0</Output16Active>
  <Output16Port>0</Output16Port>
  <Output16Pin>0</Output16Pin>
  <Output16Neg>0</Output16Neg>
  <Output17Active>0</Output17Active>
  <Output17Port>0</Output17Port>
  <Output17Pin>0</Output17Pin>
  <Output17Neg>0</Output17Neg>
  <Output18Active>0</Output18Active>
  <Output18Port>0</Output18Port>
  <Output18Pin>0</Output18Pin>
  <Output18Neg>0</Output18Neg>
  <Output19Active>0</Output19Active>
  <Output19Port>0</Output19Port>
  <Output19Pin>0</Output19Pin>
  <Output19Neg>0</Output19Neg>
  <Output20Active>0</Output20Active>
  <Output20Port>0</Output20Port>
  <Output20Pin>0</Output20Pin>
  <Output20Neg>0</Output20Neg>
  <Output21Active>0</Output21Active>
  <Output21Port>0</Output21Port>
  <Output21Pin>0</Output21Pin>
  <Output21Neg>0</Output21Neg>
  <Output22Active>0</Output22Active>
  <Output22Port>0</Output22Port>
  <Output22Pin>0</Output22Pin>
  <Output22Neg>0</Output22Neg>
  <Output23Active>0</Output23Active>
  <Output23Port>0</Output23Port>
  <Output23Pin>0</Output23Pin>
  <Output23Neg>0</Output23Neg>
  <Output24Active>0</Output24Active>
  <Output24Port>0</Output24Port>
  <Output24Pin>0</Output24Pin>
  <Output24Neg>0</Output24Neg>
  <Output25Active>0</Output25Active>
  <Output25Port>0</Output25Port>
  <Output25Pin>0</Output25Pin>
  <Output25Neg>0</Output25Neg>
  <Output26Active>0</Output26Active>
  <Output26Port>0</Output26Port>
  <Output26Pin>0</Output26Pin>
  <Output26Neg>0</Output26Neg>
  <Output27Active>0</Output27Active>
  <Output27Port>0</Output27Port>
  <Output27Pin>0</Output27Pin>
  <Output27Neg>0</Output27Neg>
  <Output28Active>0</Output28Active>
  <Output28Port>0</Output28Port>
  <Output28Pin>0</Output28Pin>
  <Output28Neg>0</Output28Neg>
  <Output29Active>0</Output29Active>
  <Output29Port>0</Output29Port>
  <Output29Pin>0</Output29Pin>
  <Output29Neg>0</Output29Neg>
  <Output30Active>0</Output30Active>
  <Output30Port>0</Output30Port>
  <Output30Pin>0</Output30Pin>
  <Output30Neg>0</Output30Neg>
  <Encoder0Active>0</Encoder0Active>
  <Encoder0APort>0</Encoder0APort>
  <Encoder0APin>0</Encoder0APin>
  <Encoder0BPort>0</Encoder0BPort>
  <Encoder0BPin>0</Encoder0BPin>
  <Encoder0Cal>1.000000</Encoder0Cal>
  <Encoder1Active>0</Encoder1Active>
  <Encoder1APort>0</Encoder1APort>
  <Encoder1APin>0</Encoder1APin>
  <Encoder1BPort>0</Encoder1BPort>
  <Encoder1BPin>0</Encoder1BPin>
  <Encoder1Cal>1.000000</Encoder1Cal>
  <Encoder2Active>0</Encoder2Active>
  <Encoder2APort>0</Encoder2APort>
  <Encoder2APin>0</Encoder2APin>
  <Encoder2BPort>0</Encoder2BPort>
  <Encoder2BPin>0</Encoder2BPin>
  <Encoder2Cal>1.000000</Encoder2Cal>
  <Encoder3Active>0</Encoder3Active>
  <Encoder3APort>0</Encoder3APort>
  <Encoder3APin>0</Encoder3APin>
  <Encoder3BPort>0</Encoder3BPort>
  <Encoder3BPin>0</Encoder3BPin>
  <Encoder3Cal>1.000000</Encoder3Cal>
  <Encoder4Active>0</Encoder4Active>
  <Encoder4APort>0</Encoder4APort>
  <Encoder4APin>0</Encoder4APin>
  <Encoder4BPort>0</Encoder4BPort>
  <Encoder4BPin>0</Encoder4BPin>
  <Encoder4Cal>1.000000</Encoder4Cal>
  <Encoder5Active>0</Encoder5Active>
  <Encoder5APort>0</Encoder5APort>
  <Encoder5APin>0</Encoder5APin>
  <Encoder5BPort>0</Encoder5BPort>
  <Encoder5BPin>0</Encoder5BPin>
  <Encoder5Cal>1.000000</Encoder5Cal>
  <Encoder6Active>0</Encoder6Active>
  <Encoder6APort>0</Encoder6APort>
  <Encoder6APin>0</Encoder6APin>
  <Encoder6BPort>0</Encoder6BPort>
  <Encoder6BPin>0</Encoder6BPin>
  <Encoder6Cal>1.000000</Encoder6Cal>
  <Encoder7Active>0</Encoder7Active>
  <Encoder7APort>0</Encoder7APort>
  <Encoder7APin>0</Encoder7APin>
  <Encoder7BPort>0</Encoder7BPort>
  <Encoder7BPin>0</Encoder7BPin>
  <Encoder7Cal />
  <RadiusCompOff>1</RadiusCompOff>
  <IJMode>1</IJMode>
  <MenuOff>0</MenuOff>
  <Debounce>0</Debounce>
  <PlasmaMode>0</PlasmaMode>
  <NoAngle>1</NoAngle>
  <IndexDebounce>0</IndexDebounce>
  <DROPERSIST>0</DROPERSIST>
  <DwellinMilli>0</DwellinMilli>
  <INIT>G80</INIT>
  <InitAllResets>0</InitAllResets>
  <AutoScreens>1</AutoScreens>
  <PulseWidth>0</PulseWidth>
  <DirPulse>0</DirPulse>
  <Vel0>0.3333</Vel0>
  <Acc0>2.</Acc0>
  <Steps0>501.0715663</Steps0>
  <Vel1>33.33</Vel1>
  <Acc1>200.</Acc1>
  <Steps1>500.5965566</Steps1>
  <Vel2>41.67</Vel2>
  <Acc2>250.</Acc2>
  <Steps2>399.7288648</Steps2>
  <AxisKeys0>39</AxisKeys0>
  <AxisKeys1>37</AxisKeys1>
  <AxisKeys2>38</AxisKeys2>
  <AxisKeys3>40</AxisKeys3>
  <AxisKeys4>33</AxisKeys4>
  <AxisKeys5>34</AxisKeys5>
  <AxisKeys6>45</AxisKeys6>
  <AxisKeys7>46</AxisKeys7>
  <AxisKeys8>999</AxisKeys8>
  <AxisKeys9>999</AxisKeys9>
  <AxisKeys10>999</AxisKeys10>
  <AxisKeys11>999</AxisKeys11>
  <DROHotKey>999</DROHotKey>
  <ListKey>999</ListKey>
  <MDIHotKey>999</MDIHotKey>
  <GCodeHotKey>999</GCodeHotKey>
  <JogFollow>0</JogFollow>
  <Slave0>3</Slave0>
  <Slave1>3</Slave1>
  <Slave2>3</Slave2>
  <M0AutoZero>1</M0AutoZero>
  <M1AutoZero>1</M1AutoZero>
  <M2AutoZero>1</M2AutoZero>
  <M3AutoZero>1</M3AutoZero>
  <M4AutoZero>1</M4AutoZero>
  <M5AutoZero>1</M5AutoZero>
  <GExt>*.tap</GExt>
  <GPath>C:\Documents and Settings\Owner\Desktop\20060.tap</GPath>
  <MRU10>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia dziury na 5 mm parts1.tap</MRU10>
  <MRU9>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia 5 numer 1.tap</MRU9>
  <MRU8>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia koncowka 3mm.tap</MRU8>
  <MRU7>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia 3mm parts 2.tap</MRU7>
  <MRU6>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia wycinanie part 3 6mm.tap</MRU6>
  <MRU5>C:\Documents and Settings\Owner\Desktop\biki do cnc.tap</MRU5>
  <MRU4>C:\Documents and Settings\Owner\Desktop\uchwyt od strony rotery table\koncowki do wymielenia 5 numer 1.tap</MRU4>
  <MRU3>C:\Documents and Settings\Owner\Desktop\uchwyt od strony rotery table\koncowki do wymielenia 3mm parts 2.tap</MRU3>
  <MRU2>C:\Documents and Settings\Owner\Desktop\koncowki do wymielenia 1680.tap</MRU2>
  <MRU1>C:\Documents and Settings\Owner\Desktop\20060.tap</MRU1>
  <BackX>1.1e-002</BackX>
  <BackY>0.</BackY>
  <BackZ>0.</BackZ>
  <BackA>0.</BackA>
  <BackB>0.</BackB>
  <BackC>0.</BackC>
  <BackSpeed>20.</BackSpeed>
  </Preferences>
- <VideoPlugIn>
  <DROcolor>1178909</DROcolor>
  <TOOLcolor>255</TOOLcolor>
  <CROSScolor>16777215</CROSScolor>
  <ShowTool>0</ShowTool>
  <ShowMousePos>0</ShowMousePos>
  <ShowAxisPos>0</ShowAxisPos>
  <FlipAxis>0</FlipAxis>
  <ToolDia>0.5</ToolDia>
  <ScaleFactor>2.e-003</ScaleFactor>
  </VideoPlugIn>
- <Control>
  <Default>0</Default>
  </Control>
  </profile>
