Hello Guest it is November 10, 2026, 01:56:07 AM
Author Topic: Micro drip system  (Read 8463 times)
Micro drip system
« on: May 04, 2011, 12:43:13 PM »
Hi There, I have 2 questions
I am trying to find some way to use a peristaltic pump to add oil drops to my engrave, so I found a pump to do that but It can not run continuously, is there any way to the mach3 turn on 5 sec and off for 20sec a parallel port pin when the spindle is on?
When the gcode finish is there any way to the z axis will be more high than a 1mm? I always has to change manually the z en the gcode
Gianni
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Micro drip system
« Reply #1 on: May 05, 2011, 04:51:41 AM »
Hi Gianni
see attached brain - it assumes your spindle is on OUTPUT1 and your pump is on OUTPUT2 - edit to suit.
your z will go wherever your gcode tells it to. If you're using CAM - change the settings there.
Ian
« Reply #2 on: May 05, 2011, 09:44:40 AM »
Ian, works great Thank you very much. You help me to discover a new part of the software.
Gianni
