Hello Guest it is November 12, 2026, 02:10:20 AM
Author Topic: MPG Jogging Error - "Galil Error 46: Gear axis both master and follower"  (Read 11802 times)
I'm working on a 4 axis mill w/ a handwheel used as an MPG input.  The Mach XYZ axes are mapped to Galil XYZ, the Mach A is mapped to Galil E, the MPG is using the main encoder on Galil D.  Jogging X, Y, and Z via the handwheel works fine, selecting Mach axis "A" causes a Galil error to appear on the status line, says "Galil Error 46: Gear axis both master and follower" ...
So did I set up something wrong?  Or is there something wrong with the axis mapping in the MPG code?  Or....?
Thanks!
Offline kcrouch
  •  193 193
  • In way too deep!!!
Sorry,
The MPG code isn't set up for axis re-mapping in the current release. It will happen on the next release or two though.
Kenny
Having way too much fun! Something must surely be wrong.
