Hello Guest it is October 04, 2026, 10:47:56 AM
Author Topic: Hiking trail symbol g-code needed  (Read 21313 times)
« on: April 27, 2011, 07:09:51 AM »
I need a g-code for the international hiking trail symbol.  See attached jpeg for an example.  Any help would be appreciated.
  •  9,374 9,374
Re: Hiking trail symbol g-code needed
« Reply #1 on: April 27, 2011, 11:48:53 AM »
I need more details of your requirement.
Do you want to route out the white part of just the outline ?
How big and what diameter tool also how deep ?
« Reply #2 on: April 27, 2011, 07:40:00 PM »
I want to route out the white part.  The symbol is approximately 2.5" wide.  I assume that a 0.125" tool would be about right. Depth does not make any difference, but probably 0.125" also.
Thanks for your help.
« Reply #3 on: April 27, 2011, 09:37:11 PM »
Here's your Gcode for the trail Logo.
Please, take great care about using it, I did not test it.
Height is 12 inches height, use the scale option in Mach3 to made the dimension you need.
Tool is .125 end mill at .125 deep.
Jeff
  •  9,374 9,374
« Reply #4 on: April 28, 2011, 01:13:42 AM »
Looks like Jeff beat me to it.  ;D
« Reply #5 on: April 28, 2011, 04:38:14 AM »
AGAIN
 ;D ;D ;D
Jeff
« Reply #6 on: April 28, 2011, 06:57:22 AM »
Thanks to both Jeff and Tweakie.   I am traveling this week, but will give it a try when I get back home/
Julian
« Reply #7 on: April 29, 2011, 08:29:10 AM »
Converted from g-code to dxf so I could see the path and try out a program.
