Hello Guest it is October 21, 2026, 10:18:19 AM
Author Topic: Motor Tuning not showing up  (Read 9794 times)
« on: April 23, 2011, 11:47:58 PM »
Hello
I have windows XP on both my mill computer and desktop unit , when ever I try to access motor tuning on either it will not come up like wtf I can only access it on my laptop can anyone explain this to me
Thank you for any insites here
Re: Motor Tuning not showing up
« Reply #1 on: April 24, 2011, 06:34:36 AM »
Look's like a modified screen. Load the standard screen and see if all works.
VIEW tab/ LOAD SCREEN/ select 1024.set
  •  9,374 9,374
« Reply #2 on: April 24, 2011, 06:42:12 AM »
Hi Peter,
Looks like you don't have the drivers installed. Run the 'Driver Test.exe' in the Mach3 folder, that should cure it.
« Reply #3 on: April 24, 2011, 09:22:27 AM »
I did some reading in the search feature and at one time or another had renamed the Mach3 folder , all I did was reinstal Mach again and all is well , the modified screen has nothing to do with this problem . I do want to thank you guys for taking the time to help me
PZ
