Hello Guest it is October 20, 2026, 05:06:11 PM
Author Topic: PWM VS Pins 2-9  (Read 12019 times)
PWM VS Pins 2-9
« on: April 20, 2011, 09:26:07 PM »
Why is it that i can only get Mach to output a PWM signal on pins 2 through 9???
Pins 1, 14,16 &17 are output pins as well but no matter what i do i cannot get a PWM signal on these pins. but pins 2-9 work just fine???
 I see that Mach has a setting to use port2 pins 2-9 as inputs instead of outputs. I was hoping to use that functionality but i can if i cant get a PWM signal to work on pins 1, 14,16 or 17
Re: PWM VS Pins 2-9
« Reply #1 on: April 20, 2011, 09:36:58 PM »
I use PWM to control a Super PID speed control and use either pin 14 or 16, but don't know which right now.
What are you trying to do?
Re: PWM VS Pins 2-9
« Reply #2 on: April 20, 2011, 09:41:25 PM »
I need to output the pwm signal to my custom built motor controller.
I looked at the SuperPID units and the units i saw are not PWM....Pulse Width Modulated. they are a traic based controller. how are you interfacing the PWM signal to the SuperPID??
Re: PWM VS Pins 2-9
« Reply #3 on: April 20, 2011, 09:49:51 PM »
I built a simple circuit to convert the PWM to 0-5V. It's on page 22 of the manual, and only cost a few $.
http://www.vhipe.com/product-private/SuperPID-v1_Instructions.pdf
Re: PWM VS Pins 2-9
« Reply #4 on: April 20, 2011, 09:54:40 PM »
I built a custom motor controller that takes the PWM signal, opto isolates it and feeds it to a IC Mosfet driver and then to a power Mosfet to control the spindle motor directly. works great! But i want to use Pins 1, 14,16 or 17 to output the PWM signal.
 I have a dual Parallel port card in my PC. and i tried both ports and same deal.
Re: PWM VS Pins 2-9
« Reply #5 on: April 27, 2011, 05:54:09 AM »
I am having other problems now. I moved things around to get a PWM output from pin 6 and its not working. I have figured out that if i press the rest button the PWM will start. but only at the minimum speed. If i press the speed up/down buttons it just shuts off.
 I want to use 400hz as my PWM base frequency. I have a direct drive spindle. I have the pulley ratio set for 5000min and 30000max with a ratio of 1
