Hello Guest it is November 13, 2026, 03:42:04 PM
Author Topic: shapes wizzard  (Read 14380 times)
shapes wizzard
« on: April 19, 2011, 02:55:38 PM »
Hello
In the shapes wizzard when i try to input a cutter diameter of .125 it only rounds it up to .13 is there a way to change it so it accept a 3 digit number
thank you for your time
Marcel Beaudry
Re: shapes wizzard
« Reply #1 on: April 19, 2011, 03:07:49 PM »
Hi Marcel,
  The value that you enter is valid and accurate even though the DRO only shows 2 decimal places.
But if you want to change it, open the .set with Screen4 from the Mach3 folder/addons/shapes, double click the DRO and change the 2 to 4 (%+.4f)
Russ
Re: shapes wizzard
« Reply #2 on: April 19, 2011, 03:10:21 PM »
... or,  %+.3f  for 3 decimal places.
Re: shapes wizzard
« Reply #3 on: April 19, 2011, 03:31:25 PM »
That was fast
So if i input .1875 the program will use .1875 and put .19 in the box.
Thank you for your time
Marcel
Re: shapes wizzard
« Reply #4 on: April 19, 2011, 03:34:55 PM »
Yes.
Re: shapes wizzard
« Reply #5 on: April 19, 2011, 03:37:30 PM »
Well i thank you again for your time
Marcel Beaudry
Re: shapes wizzard
« Reply #6 on: April 19, 2011, 03:43:12 PM »
Hey Marcel, I want to experiment with this a bit to be sure. I know I saw this before in another wizard but better check this one for sure.
I don't want to mis inform you.
You might have to change it as I mentioned earlier.
Russ
Re: shapes wizzard
« Reply #7 on: April 19, 2011, 04:07:56 PM »
I'm not so sure about this one Marcel.
Whatever I seem to do, the final code produced is rounded to 2 decimal places.
Probably well suited for metric ops, not so good for INCH.
I'll stand by for a possible solution.
Proceed with caution.
Sorry,
Russ
Re: shapes wizzard
« Reply #8 on: April 19, 2011, 04:16:25 PM »
Thank You
It works for me
Marcel
